180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. R1559904272203
    Donut Jun 30, 2019
    R1559904272203 , Jun 30, 2019 :
    i think its based on which country you are in
  2. alttafv
    Eclair Jun 30, 2019
    alttafv , Jun 30, 2019 :
    I'm in india
    R1559904272203 likes this.
  3. R1559904272203
    Donut Jun 30, 2019
  4. alttafv
    Eclair Jun 30, 2019
  5. oneshotaz
    Eclair Jun 30, 2019
    oneshotaz , Jun 30, 2019 :
    I am going to sound jealous and greedy. but how come we are still stuck on the May security update but the OnePlus 7 got it?
    idbl_fanatic1 likes this.
  6. R1559904272203
    Donut Jun 30, 2019
  7. oneshotaz
    Eclair Jun 30, 2019
  8. J1561909919456
    Cupcake Jun 30, 2019
  9. alexmidd
    Eclair Jun 30, 2019
    alexmidd , Jun 30, 2019 :
    Having the default region for assisted dialling option as "England" is a bit annoying for those of us that live in the UK but not England. It's like if it said "Rajasthan" instead of "India".
    Huigiebaby and RogerAnderson like this.
  10. idbl_fanatic1
    Ice Cream Sandwich Jun 30, 2019
  11. Swejuggalo
    Jelly Bean Jun 30, 2019
    Swejuggalo , Jun 30, 2019 :
    This will come in next update. My guess would be in just a couple of days
    Gunjan Ft Shady likes this.
  12. rclotz
    Honeycomb Jun 30, 2019
    FRJerome likes this.
  13. moonkin91
    Froyo Jun 30, 2019
    moonkin91 , Jun 30, 2019 :
    Ghost touches still happen on apps like WhatsApp, stock messages app, and Chrome. You haven't fixed this. Turning NFC off is the only way to stop the phantom touches, but I NEED NFC daily, it is not a solution.
    WhatsApp messages a d Gmail messages are also severely delayed until the app is opened, where as my Pixel 3a everything is instant. Changing battery optimisation etc doesn't fix it.
    Awful update.
    falconmoonpunch likes this.
  14. abhi1406
    abhi1406 , Jun 30, 2019 :
    The night mode automatically turns back on even when I switch it off manually from quick settings. I have turned on the automatic sunset to sunrise night mode. On my previous oneplus device, it would stay off till i switched it on back manually. Can it be corrected in future updates?
  15. idbl_fanatic1
    idbl_fanatic1 , Jun 30, 2019 :
    I wish brightness would go up when opening YouTube, also I wish that when I am playing a game that the screen off timeout would be overwritten
  16. O1560887023118
    Eclair Jun 30, 2019
    O1560887023118 , Jun 30, 2019 :
    new battery milestone. almost a full 48 hrs on a single charge with over 10 hrs of screen time. I am pleasantly surprised. If you aren't happy just wait the phone eventually optimizes the RAM and battery and your battery life will significantly improve. Very impressed One Plus!!!
  17. U1561533367105
    U1561533367105 , Jun 30, 2019 :
    Hi i have some problem. As the conversation is carried out via the handset, this is ok. The problem appears on the hands-free. I hear everything but my interlocutors say that when they start talking to me, it cuts my conversation. As long as we are talking in a different way, this is ok. If someone starts talking to me, he immediately cuts off my voice in the receiver. The problem is on the side of my interlocutor and not on my device.
    Someone have the same problem ? OP have some solutions for this ??
  18. Sheeng12
    Sheeng12 , Jun 30, 2019 :
    one thing i noticed is that when we are in landscape mode and you swipe home you get a little bit of lag and when you are in portrait mode well you get a smooth exit or and I think that's an issue that can be fixed by software, I will like the same smoothness has portrait mode.
  19. Swejuggalo
    Do anyone else see this delay of gray/black colors? Look at Realcalc icon for example.
    https://1drv.ms/v/s!AkFQC_-2GManz3dZk30vlUm-RXKH
    Running Nova launcher with completely black backgroud.
    Think I've seen someone mentions similar effects....
    Try this in a dark room with low screen brightness. Then it's very clear. If I crank up the brightness it nearly goes away and probably will be hard to notice at max brightness I guess.
    Worth mentioning.... Same effect can be seen on a Samsung s10+. Maybe possible to tweak but I guess this could be a limitation of this type of screen.
    7Pro.user likes this.
  20. Oneyedmonkey
    Honeycomb Jul 1, 2019
    Oneyedmonkey , Jul 1, 2019 :
    I wish I could reach through your screenshot and clear your notification bar...
