180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. rockthisfellah Eclair Jul 3, 2019
    rockthisfellah, Jul 3, 2019 :
    What does the (1-3) do on selfie camera? I tried each of the numbers and didn't notice a difference on any?
  2. Cooldrewf Froyo Jul 3, 2019
    Cooldrewf, Jul 3, 2019 :
    it controls the level of the beauty mode. 3 is the most so ur skin would look smoother on level 3
  3. rockthisfellah Eclair Jul 3, 2019
    Oh, thats what it was. Awesome, ty for the quick reply!
  4. R1558910837372 Froyo Jul 3, 2019
    R1558910837372, Jul 3, 2019 :
    Recommended way is to try it on your selfie face and you will see the difference between 0-3
  5. Sachin100 Donut Jul 3, 2019
    Sachin100, Jul 3, 2019 :
    hi guys is it ok??
    i charged it full in morning at 9
    and now its 8:16. night
    but Screen on time is just. 2hrs 38 mins
    please comment
    SOT 2HR 38 MINS.
  6. rockthisfellah Eclair Jul 3, 2019
    What are your settings? (90hrtz,60)? And display set too?
  7. Sachin100 Donut Jul 3, 2019
  8. Sachin100 Donut Jul 3, 2019
    FHD+
    AND 90 HERTZ
  9. P1561589408180 Donut Jul 3, 2019
  10. rockthisfellah Eclair Jul 3, 2019
    Have you tried using 60hrtz all day? And how much battery did you have compared to the 90hrz?
  11. G_adrian_strozier_kHOO Eclair Jul 3, 2019
    rockthisfellah likes this.
  12. G_El_Hadj_Chitou_zagD Donut Jul 3, 2019
  13. R1558910837372 Froyo Jul 3, 2019
  14. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jul 3, 2019
    KeepTransisting, Jul 3, 2019 :
    Try uninstalling Instagram. See if that helps
  15. Gunjan Ft Shady Froyo Jul 3, 2019
    Gunjan Ft Shady, Jul 3, 2019 :
    A lot of lag and Sluggishness is observed after this update.... it's not as smooth as before...
    AdikartaDasa and mbcool like this.
  16. R_d_M Froyo Jul 3, 2019
    R_d_M, Jul 3, 2019 :
    yes, this update made batterylife terrible for me.
    animations are indeed not as fluid as before
    Gunjan Ft Shady likes this.
  17. Soulbruva Froyo Jul 3, 2019
    Soulbruva, Jul 3, 2019 :
    liar. let me see your app usage
  18. T1562188924799 Cupcake Jul 3, 2019
    T1562188924799, Jul 3, 2019 :
    Hi i just received my update and after my update i am facing problems in whatsapp, insta and fb with respect to images
  19. Demon_hunter Honeycomb Jul 3, 2019
    Demon_hunter, Jul 3, 2019 :
    that is a worldwide problem of fb owned apps..nothing to do with oneplus update
  20. H3FTA Cupcake Jul 3, 2019
    H3FTA, Jul 3, 2019 :
    When will any of this actually be rolled out to the 5G I've had one update since purchase and that's still at least .4 behind.
