180
OxygenOS 9.5.8 for OnePlus 7 Pro
  1. G_Hitendra_Singh_chouhan Cupcake Jul 5, 2019
    G_Hitendra_Singh_chouhan, Jul 5, 2019 :
    Here is the screen shot of the same
    J1561481504323
    Its confusing. You said "when i swipe right" in your earlier post. Do you mean swipe right on home screen or did you mean swipe up (from bottom) on home screen?
    Thanks,
    Vinod​
    thanks for the reply and sorry if you got confused !!
    let me rephrase it !! I unlocked the phone and from the main screen i have the gesture as < _ !! so when i swip righ the _ i am always getting the launcher setting !! but i should get either the recent app or the default msg when there is no recent app
  2. Yoshi12JJ Cupcake Jul 5, 2019
    Yoshi12JJ, Jul 5, 2019 :
    Battery sucks now like why? fully charged 100% and then like 12 minutes later it's already on 90% why?? Is it cause of the update??? it never used to do that before...
    G_SudarsaN_c_foSK and V3X11 like this.
  3. P1561589408180 Donut Jul 5, 2019
  4. P1561589408180 Donut Jul 5, 2019
    P1561589408180, Jul 5, 2019 :
    its happen again oneplus,please fix it asap!!!
  5. V3X11 Froyo Jul 5, 2019
  6. VinodGOP7 Froyo Jul 5, 2019
    VinodGOP7, Jul 5, 2019 :
    Mmm...I do not use "Back, home" gesture mode. Anyway, I just switched to "Back, home" gesture mode and tried swiping on the "_" bar. Here is my observation. If I clear all my apps from recent apps, then the only recent app that shows when i swipe on "_" bar is the launcher settings window, but if I have not cleared the recent apps, then it shows my recent apps along with launcher settings window when I swipe on "_".
    I had cleared all recent apps. So it shows me only launcher settings window in the below screenshot
    image below has recent apps (chrome window can be seen on the left)
    Are you sure, you have not cleared your recent apps before trying this?
    Can you open other apps (and do not clear it) and try again?
    Thanks,
    Vinod
  7. G_Hitendra_Singh_chouhan Cupcake Jul 5, 2019
    yup ,when i have something opened and then look for the recent app ,it the only shows me the actual recent app !! I have actually fixed it by
    Settings>> Apps & Notifications>> See all apps>> click on 3 dots on top right corner>> Reset app preference
  8. E1560338111654 Cupcake Jul 5, 2019
    E1560338111654, Jul 5, 2019 :
    tengo problemas con la última actualización toques fantasmas muchos ademas, no me deja bajar la barra de notificaciones en ninguna aplicación, solo en el fondo de pantalla a alguien más le pasa?
  9. Louioo Honeycomb Jul 5, 2019
    Louioo, Jul 5, 2019 :
    Show of hands in the UK who received their 9.5.5 update on the OPO7Pro today! :)
  10. akks Ice Cream Sandwich Jul 5, 2019
    akks, Jul 5, 2019 :
  11. Subhamprasad191 Cupcake Jul 5, 2019
    Subhamprasad191, Jul 5, 2019 :
    after update my newly bought phone has started showing some problem please rectify it in the new update.
  12. Soulbruva Froyo Jul 5, 2019
    Soulbruva, Jul 5, 2019 :
    why hasn't the camera app updated to its latest version 3.4.19 when I updated the OS to 9.5.8. Are we supposed to update the camera app manually? and is 3.4.19 the official latest version?
    Sheeng12 likes this.
  13. Swejuggalo Jelly Bean Jul 5, 2019
    Swejuggalo, Jul 5, 2019 :
    The camera gets updated when updating the firmware. The reason there exists other and newer apks is that they come from developer previews, betas and such.
  14. Gueroh Cupcake Jul 5, 2019
    Gueroh, Jul 5, 2019 :
    I really like the gesture navigation because of the extra screen space it gives you but with a case sometimes it's hard to get it to work properly, you cant get your finger low enough every time to do it consistently. It would be really nice if you could hide the notification bar when web browsing on Chrome for a true full screen experience. When highlighting text all the way at the edge of the screen it can be hard to get the first couple letters selected. Perhaps a setting specifically for bulkier cases should be added that gives a slight buffer to where you are touching the screen near the edges. When setting up the phone initially you get a notification to connect to wifi and you can't get it to go away until you connect to wifi which is really annoying.
    Arjun_Chaturvedi likes this.
  15. Huigiebaby Honeycomb Jul 5, 2019
    Huigiebaby, Jul 5, 2019 :
    It is so difficult to respond in a normal matter on this kind of posts...
    Seriously, how the hell does one fix some problem when you do not state what the problem is? OP does not provide brain surgery. Maybe there is an app for that, I would look for it asap!
    no need to respond, you sir, made my list....
  16. Subhamprasad191 Cupcake Jul 5, 2019
  17. Subhamprasad191 Cupcake Jul 5, 2019
    are you working in one plus!
  18. VinodGOP7 Froyo Jul 5, 2019
    Interesting to note the resolution. Anyway, glad you were able to resolve the issue.
    Thanks,
    Vinod
  19. FRJerome Ice Cream Sandwich Jul 5, 2019
    FRJerome, Jul 5, 2019 :
    You just got what I call a very clever response to a very stupid question.
    If you have an issue try at least to tell what your issue is.
    If you have a precise one there is a support part on oneplus.com
  20. Subhamprasad191 Cupcake Jul 5, 2019
    is it a sarcasm because I have already mentioned above my issue.
