365
OxygenOS Android 10 Open Beta 1 for OnePlus 5/5T
  1. Bikash sahoo
    Eclair Apr 28, 2020
  2. athuljood
    Cupcake Apr 28, 2020
    athuljood , Apr 28, 2020 :
    I'm facing a similar issue rn. Were you able to find a solution for this ?
  3. G_samitmunikar
    Eclair Apr 28, 2020
  4. rahulkr.ver
    Gingerbread Apr 28, 2020
    rahulkr.ver , via OnePlus 5 , Apr 28, 2020 :
    first save data , then updated your phone, & wiped all data , then upload your data. .
    then there is no lag. ok
    F1520611303105 likes this.
  5. rahulkr.ver
    1st go to recovery mode then wiped all data then try.
    Anas Multani likes this.
  6. rahulkr.ver
    mera to show ho rha hai.
  7. rahulkr.ver
  8. G_samitmunikar
    Eclair Apr 28, 2020
  9. rahulkr.ver
    i am a OnePlus 5 user , Not OnePlus 5t
    so plz make sure , which you had updated, op5 Or Op5t ?
  10. rahulkr.ver
    1st save your all data .
    then updated your mobile.
    then go to recovery mode & wiped all data,.
    then restart your mobile.
    & upload all your file in your mobile.
    let's do that.
  11. kr.rahul27
    Honeycomb Apr 28, 2020
  12. parthiv009
    Jelly Bean Apr 28, 2020
  13. being_nabnit
    Froyo Apr 28, 2020
  14. G_samitmunikar
    Eclair Apr 28, 2020
    G_samitmunikar , via OnePlus 5T , Apr 28, 2020 :
    obviously OnePlus 5T version updated bro
  15. rahulkr.ver
  16. Pranay Verma
    Eclair Apr 28, 2020
    Pranay Verma , via OnePlus 5 , Apr 28, 2020 :
    No I guess they can't, 5T just like the newer devices has no dedicated navigation keys and 5 doesn't. So I guess 5 users won't get these navigation gestures as they'll be just creating a duplicate feature as to what can be done using hard buttons
  17. G_samitmunikar
    Eclair Apr 28, 2020
  18. rahulkr.ver
    that is the reason you are facing problem. wait. i am sending a link. ok
  19. G_samitmunikar
    Eclair Apr 28, 2020
    I am sure that it was a official link of update version zip file
  20. Jim AL Sadik
    Donut Apr 28, 2020
    Jim AL Sadik , via OnePlus 5T , Apr 28, 2020 :
    How I'll get the next update of this if i flash this on my OP5T? via OTA or again flashing from recovery? I mean, is that rom will get OTA update or not?
