365
OxygenOS Android 10 Open Beta 1 for OnePlus 5/5T
  1. hbhansal
    Gingerbread Apr 28, 2020
    Anas Multani likes this.
  2. Irish007
    Cupcake Apr 28, 2020
    FusionBomber likes this.
  3. Irish007
  4. Some_Random_Username
    Community Bug Hunter Apr 28, 2020
    Some_Random_Username , Apr 28, 2020 :
    @Manu J.
    Please forward to engineering team that OTA blocks when a stable build will be released will have to be put in place for users still on Oreo builds from 5.1.4 included to 5.1.7 included as otherwise camera will not work at all. Upgrading to at least OOS 9.0.0 before going to Q is mandatory to avoid that issue.
  5. Rishab_Lahari
    Rishab_Lahari , Apr 28, 2020 :
    Typing on the oxygen os 10.0 of OnePlus 5.
    No issues found as of now. The battery life is not as good - that is the only issue.
    However, the new update is[e]1f525[/e][e]1f525[/e] and the phone is still fluid af.
    Thanks OnePlus for supporting this device for so long
    Have a wonderful day.
    - From Rishab Lahari. A OnePlus fan
    anandsiddharth likes this.
  6. Irish007
    Irish007 , via OnePlus 5T , Apr 28, 2020 :
    you can if your on stable 9.0. download zip to internal storage or copy it from downloads. Then you go to updates in settings click on cog wheel in right corner. Select local upgrade and your zip file you downloaded is there. I installed this way n didn't lose data. Only if you have twrp and are on an ob 33 for 9.0
  7. Irish007
  8. Irish007
    should work magisk is systemless. I downloaded zip and copied it to root of internal storage and then went to system updates in settings and went local upgrade and flashed it works fine but I'm also not rooted but ill be trying it.
  9. JeromeH.
    Donut Apr 28, 2020
  10. Keerthyvasan26
    Eclair Apr 28, 2020
  11. Babai@1
    Babai@1 , Apr 28, 2020 :
    Is it available in india, till yet I didn't got the update notification!!!
  12. Gautam_bafna
    Gautam_bafna , via OnePlus 5T , Apr 28, 2020 :
    You have to download it manually from the links given above.
  13. anandsiddharth
    anandsiddharth , via OnePlus 5 , Apr 28, 2020 :
    Round is before cube in the customisation section. So just swipe to go left and you'll have the round icons there.
  14. Ma_Fi
    Eclair Apr 28, 2020
  15. Aamir Aman
    Eclair Apr 28, 2020
    G_T_Bennett likes this.
  16. Jim AL Sadik
    Donut Apr 28, 2020
    Jim AL Sadik , via OnePlus 5T , Apr 28, 2020 :
    If i install this beta maually, then how will i get future beta updates? via OTA or need same as manual install?
  17. mark133
    mark133 , Apr 28, 2020 :
    Anyone got a Galaxy S3 watch? Mine keeps dropping the Bluetooth connection and won't reconnect
  18. vip+1
    Froyo Apr 28, 2020
    vip+1 , via OnePlus 5 , Apr 28, 2020 :
    thanks brother, i was searching for the solution for this, works with banking apps too.
    Vikky insta likes this.
  19. vip+1
    Froyo Apr 28, 2020
    disable volte vowifi, they will work
  20. Babai@1
    Is it safe while from downloading from the above link because in the official it is yet not showing up
