366
OxygenOS Android 10 Open Beta 1 for OnePlus 5/5T
  1. Marcoziezo
    Honeycomb Apr 29, 2020
  2. remantchopra
    Froyo Apr 29, 2020
    Marcoziezo likes this.
  3. remantchopra
    Froyo Apr 29, 2020
  4. remantchopra
    Froyo Apr 29, 2020
  5. Repsimus
    Cupcake Apr 29, 2020
  6. SiddharthBokaria
    Gingerbread Apr 29, 2020
  7. Deactivated User
    Apr 29, 2020
    ArvindSinghK likes this.
  8. choby
    choby , Apr 29, 2020 :
    i have install netflix and disney plus from apk mirror....use theyr tool to install multiple apks and all works fine.
  9. remantchopra
    Froyo Apr 29, 2020
  10. afnan_s
    Donut Apr 29, 2020
    afnan_s , Apr 29, 2020 :
    Hi All,
    Good OnePlus still cares for the older mobiles and provides the latest updates for these mobiles. Having said this I installed the Android 10 beta 1 on my OnePlus 5T. After using for about 3 days now I have the following issues
    1. Draining battery ( hardly getting 2hr 30 min screen on time )
    2. I would prefer the OnePlus gestures rather than the Android gestures
    3. The back gesture is very buggy as it sometime does not work
    4. Seen a lot of wifi disconnect issue and also wifi connectivity issue.
    I agree that this is just a first beta version and it is ment to have issue. Hopefully OnePlus will fix them.
    Can anyone tell me how I can go back to the Android 9 stable version.
    Regards,
    Afnan Shaikh
  11. ash_insiider
    ash_insiider , via OnePlus 5T , Apr 29, 2020 :
    clear cache and wipe data from recovery and select zip for stable 9.0
  12. afnan_s
    Donut Apr 29, 2020
  13. Cdub76
    Cdub76 , Apr 29, 2020 :
    One bug I noticed is that Google messages crashes once you start typing.
    afnan_s likes this.
  14. afnan_s
    Donut Apr 29, 2020
    afnan_s , via OnePlus 5T , Apr 29, 2020 :
    I am also facing this issue
  15. SurajLoharia
    KitKat Apr 29, 2020
  16. audi_mc
  17. ash_insiider
    go to developer options and select advance reboot.
    hold power button to see this menu and click recovery,
    your phone will go into recovery mode and click on the wipe/clear cache and data
    and click on install from device and you be able to see your file if placed in root. and select the file and proceed.
  18. jgcaap
    Ice Cream Sandwich Apr 29, 2020
    jgcaap , Apr 29, 2020 :
    If it was like me, you also need to format SD card before flashing.
  19. KG_VENKATESH
