366
OxygenOS Android 10 Open Beta 1 for OnePlus 5/5T
  1. Meherbanali
    Froyo Apr 30, 2020
    Meherbanali , via OnePlus 5T , Apr 30, 2020 :
    factory reset is needed
  2. Cervantes
    Moderator Moderator Apr 30, 2020
    Cervantes , Apr 30, 2020 :
    the report form has some alternatives
    You can use system and one of the alternatives
    Freeze & Reboot, Heating & Power, Charging, System Lag, OTA
    You can complement the description with a screenshot, photo, video
  3. NofanTasi
    Cupcake Apr 30, 2020
  4. NofanTasi
    NofanTasi , Apr 30, 2020 :
    I know, but as said, I cannot select Oneplus 5T 10.0.0 Beta1
  5. Meherbanali
    Froyo Apr 30, 2020
    I have faced such issues earlier,
    solution 1 try clearing caches
    solution 2 reset you device.
  6. NofanTasi
    ' is needed' seems not a generic statement then.
    Thanks anyway I will wipe dalvik en clear cache (but I wish I should not factory reset).
  7. Meherbanali
    Froyo Apr 30, 2020
    "is needed" was the solution for me
  8. NofanTasi
  9. NofanTasi
  10. gopalan.md19
    Gingerbread Apr 30, 2020
  11. Anas Multani
    Donut Apr 30, 2020
  12. Jim AL Sadik
    Donut Apr 30, 2020
    Jim AL Sadik , via OnePlus 5T , Apr 30, 2020 :
    Finally installed it (about 12 hour ago). Everything ok, no bugs. Old version apps shows warning about OS. Very much smooth UI. Battery backup ok. Problem is the messaging app doesn't working. Laggy dial and calling options. Call recording working. Camera same as past. Display and flashlight brightness a little bit higher than before i think. Everything seems to ok at all.
  13. thiagomz
    Donut Apr 30, 2020
  14. Naved.shaikh
    Cupcake May 1, 2020
  15. ruijmeira
    Gingerbread May 1, 2020
    ruijmeira , May 1, 2020 :
    Can you please read the original post before commenting?
  16. omar460
    Eclair May 1, 2020
    omar460 , May 1, 2020 :
    Please bring back full bottom gestures that was in OS9
    the back functionality from right and left is not as smooth as from the bottom
    deatsev and markitosd like this.
  17. U1545146487796
    Cupcake May 1, 2020
    U1545146487796 , May 1, 2020 :
    Good night guys, I would like to know if it is safe to proceed with root on the device with this beta version of android 10 .. Or is there a problem in relation to this? Oneplus 5t
  18. getnimesh
    Donut May 1, 2020
  19. Palashlunkad
    Eclair May 1, 2020
  20. Palashlunkad
    Eclair May 1, 2020
    Palashlunkad , May 1, 2020 :
    The only problem is battery drain issue rest everything is fine
