917
OxygenOS Android 10 Open Beta 1 for the OnePlus 6 and OnePlus 6T
  1. Kunalb007
    Cupcake Oct 20, 2019
    Kunalb007 , via OnePlus 6 , Oct 20, 2019 :
    Android 10 updated. But problem is calculator not working.
    although i have reported for this bug.
    Hopefully it will fix asap.
    Thnaks.
    khyathi123 likes this.
  2. W1571602556300
  3. kylesare57
    Eclair Oct 20, 2019
  4. TheMysticalShaman
    Honeycomb Oct 20, 2019
  5. itsmichaelmurphy
    Donut Oct 20, 2019
    itsmichaelmurphy , Oct 20, 2019 :
    I have tried twice on my OnePlus 6T T-Mobile variant to upgrade to the newest Open Beta. It runs the current open beta released in September just fine. But then when I do a local upgrade to the Android 10 open beta, right after it finishes installing and I press reboot, I get a message that says Build Version and HW version do not match and it ets stuck in a bootloop. To fix it, I have to use MSMDownloadTool to fix it. I have tried doing a local upgrade using a locked and unlocked bootloader and both lead to the same problem. Has anyone succesfully updated their TMo variant because i hate having to keep restoring my device?
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 20, 2019
    Caomhin , via OnePlus 6T Mirror Black , Oct 20, 2019 :
    What issue/error are you getting on the 6. Works fine on the 6T
  7. Adinem
  8. Caomhin
    itsmichaelmurphy
    Needs to be the international version. If its tied to a network, you may have the issues you mention. You will need to wait for the version your carrier releases, if you are tied to that carrier.
    If you read the first post above, it will explain this already.
  9. aakashmaji16
    Gingerbread Oct 20, 2019
    aakashmaji16 , via OnePlus 6T , Oct 20, 2019 :
    Is it me or somebody here facing this:
    If you keep your brightness at the lowest and type on the keyboard on whatsapp
    The screen slightly blinks just how the fingerprint sensor lights that part for a second.
    Do like this post for considering this as you are facing it too!
  10. Caomhin
    Restart your phone, if you still experience the issue, submit a bug report with the link on the first post. Have not experienced the issue you mention on a 6T.
  11. BRAD FORD BOI
    BRAD FORD BOI , via OnePlus 6 , Oct 20, 2019 :
    bug i turned off my developer option and it disappeared tapping on build number several times is not working tried restarting, clearing cache from recovery and even reinstalling the update just can find developer option again
  12. F1569953086758
  13. aakashmaji16
    Already done posting a bug report.
  14. A1547016063213
    A1547016063213 , Oct 20, 2019 :
    i'm using oneplus 6. i get a beta update, which was android 10. but after installing the update both side rotation is not working. i'm expecting the solution very soon.
  15. mattish.91
    Froyo Oct 20, 2019
    mattish.91 , Oct 20, 2019 :
    I actually got TWRP installed, however boot got lost and after rebooting out of TWRP i got stuck in "QUALCOMM Crash Dump Mode" Now i had to go back to OB17 with a full wipe. I can confirm TWRP is not for Q just yet xD
    Oh well Q was fun as long as it lasted (22 hours) xD Not going back there just yet since there is no recovery partition in Q. I believe that update will make some crazy stuff with the next coming update since recovery is not in it. (as of what i could find)
    My biggest bet is that mauronofrio over at XDA will help us out when time is right.
  16. patgr13
    Froyo Oct 20, 2019
  17. patgr13
    Froyo Oct 20, 2019
  18. khyathi123 likes this.
