917
OxygenOS Android 10 Open Beta 1 for the OnePlus 6 and OnePlus 6T
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 23, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 23, 2019 :
    I googled this and found many strange things but no real answer and good solution. Think some trial and error is needed to pin point this. One of those devices I read about was a Samsung device...
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Nov 23, 2019
    Artemus , Nov 23, 2019 :
    Disable "download article cache" in Chrome.
  3. Swejuggalo
    How does this setting look for you in Chrome? One of the possible solutions
  4. Chumdini
    Honeycomb Nov 23, 2019
    Chumdini , via OnePlus 6T , Nov 23, 2019 :
    they might be waiting on that since the last one had cts failed . I know I sent in a detailed log of the incident to them.
    ironass likes this.
  5. shravanp07
    Eclair Nov 24, 2019
    shravanp07 , via OnePlus 6 , Nov 24, 2019 :
    You've stopped developing Beta builds as well? I thought Beta versions were supposed to be a Bi-Monthly Thing. It's been a month and we haven't seen a new build and even when you do release a beta, they're too buggy unlike the older Pie Beta builds and you don't even rectify and correct those bugs before releasing the stable builds. It's funny you guys do that [e]1f60f[/e]
    Mike_Jiang and Ronesso17 like this.
  6. G1574480751242
    Cupcake Nov 24, 2019
    Ronesso17 likes this.
  7. HarryRag
    Honeycomb Nov 24, 2019
    HarryRag , Nov 24, 2019 :
    Nope, same for hard/soft-ware.
    no upgrad3/updates yet
  8. lapellot
    Donut Nov 24, 2019
    lapellot , Nov 24, 2019 :
    If I'm in the A10 beta and I want to update to the A10 stable build, can I do a backup on my PC, update to stable and recover my apps/data from that backup?
    Mike_Jiang likes this.
  9. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Nov 24, 2019
    Artemus , Nov 24, 2019 :
    Wait for the new version.
  10. L1546689274013 likes this.
  11. Artemus
    You can wait.
  12. B_Wrath
    Junior Moderator Junior Moderator Nov 24, 2019
    B_Wrath , Nov 24, 2019 :
    Competent beta testers shouldn't be update hungry. They should know how long it will take for any critical bug to sorted out.
    If you have problems with the beta update, provide feedback with logs.
    TheJeff_08, Starcommander and Artemus like this.
  13. Ronesso17
    Ronesso17 , via OnePlus 6T Mirror Black , Nov 24, 2019 :
    one month is more than enough time to iron out any bugs. Don't give excuses for their failures. it is just shameful that November is ending and still we are having the September security patch. Just shameful.
    L1546689274013 and Mike_Jiang like this.
  14. Ronesso17
  15. B_Wrath
    It depends on the bug. I have seen quite a lot of times when a bug takes 3 to 4 months to get solved.
    And I'm not giving excuses for their failures. I'm just saying there is no failure.
    And security patches are once in two months. Even Google allows up to 3 months out dated security patches.
    Starcommander, ironass and Artemus like this.
  16. DeadEyeP
    Froyo Nov 24, 2019
    DeadEyeP , via OnePlus 6 , Nov 24, 2019 :
    Only if you have an infinite number of resource can that be met.
    You have no understanding of the SDLC
  17. ImSupun
    ImSupun , Nov 24, 2019 :
    Dear Oneplus Developer Team , If You Can't Fix Bugs Quickly, Atleast Give a Security Update.
    Google Pay Not Compatible. [e]1f61e[/e]
  18. X1562517598900
  19. B_Wrath
    Where do you live?
  20. D1542836311701
    Froyo Nov 24, 2019
    D1542836311701 , via OnePlus 6T , Nov 24, 2019 :
    You're incorrect. I use Google pay everyday. I've been on beta 1 since release.
    No issues at all.
    Madgenius07 and Caoimhín like this.
