917
OxygenOS Android 10 Open Beta 1 for the OnePlus 6 and OnePlus 6T
  1. thedarkpresence_
    Gingerbread Oct 19, 2019
    thedarkpresence_ , Oct 19, 2019 :
    Wifi settings > Current wifi network > Modify > Advanced > Use device MAC
    E1592075808755 likes this.
  2. 0kti
    0kti , via OnePlus 6 , Oct 19, 2019 :
  3. pratik.tikle
  4. Maverick2.0
    KitKat Oct 19, 2019
    Maverick2.0 , Oct 19, 2019 :
    Ok. Hope I don't get stuck...Are you sure it's just the PIN that is required? ( I have PIN lock set up)
  5. BloopDoop
    Cupcake Oct 19, 2019
    BloopDoop , via OnePlus 6 , Oct 19, 2019 :
    thedarkpresence_
    Wifi settings > Current wifi network > Modify > Advanced > Use device MAC​
    my device mac changed! from what it was before the update
  6. Bghyt , via OnePlus 6T Midnight Black , Oct 19, 2019 :
    Android 10 is not supported yet xD I've said this at lease loot mate
  7. 8555918229
  8. FaisalKhanMag
    FaisalKhanMag , Oct 19, 2019 :
    Is it necessary to be on the Beta Built to get the Android 10 Beta 1 update, or can i also get it on my stable version?
  9. manasarora98
    Ice Cream Sandwich Oct 19, 2019
    manasarora98 , via OnePlus 6 , Oct 19, 2019 :
    Maybe Pin this sometime.
  10. 0kti
    Yep
  11. R1551288614678
  12. 0kti
  13. marius.iconaru
    marius.iconaru , Oct 19, 2019 :
    No.
  14. FaisalKhanMag
    From where did you update it mate?
  15. manasarora98
    Well, by default I have screen unlock pin only, its a 6 digit pin thats it, make sure you enter correctly and ya pretty sure you wont get stuck.
  16. S1558615625632
    Eclair Oct 19, 2019
    Lalit_Verma likes this.
  17. Maverick2.0
    KitKat Oct 19, 2019
    Was looking for you, man. I was planning to wipe cache (a few glitches here and there). But I revall9 that you had said that wiping the cache doesn't really do anything. Is that true in this case?
  18. dilzit
    dilzit , Oct 19, 2019 :
    Did you have swift installer? Flash boot image through fastboot and then you can boot. To get magisk again patch the boot image through the manager app and then flash it again
  19. asimo5050
