917
OxygenOS Android 10 Open Beta 1 for the OnePlus 6 and OnePlus 6T
  1. Maverick2.0
    KitKat Oct 19, 2019
    Maverick2.0 , Oct 19, 2019 :
    Mine is a 4 digit PIN...
  2. Eecif
    Eclair Oct 19, 2019
  3. yuvraj1269
    Cupcake Oct 19, 2019
    yuvraj1269 , Oct 19, 2019 :
    It is supported by Magisk 20.0. It worked when I was using Pixen OS. Its not working with OB1 though.
  4. mrinank67
    mrinank67 , Oct 19, 2019 :
    well, i cant access the recovery in this build, im always brought back to the fastboot menu
    cannot wipe cache :(
  5. rhyd1am
    KitKat Community Expert Oct 19, 2019
    rhyd1am , via OnePlus 6T , Oct 19, 2019 :
    It won't do any harm at least, but it's not really doing anything if you do
    Maverick2.0 likes this.
  6. FaisalKhanMag
    FaisalKhanMag , Oct 19, 2019 :
    I already check in the app but not upate there still, do i need to be on the beta build already or can i also get it while im on the stable build?
  7. Maverick2.0
    KitKat Oct 19, 2019
    I see...
    rhyd1am likes this.
  8. N1568018208907
  9. Danielarr45
    Honeycomb Oct 19, 2019
  10. manasarora98
    Ice Cream Sandwich Oct 19, 2019
  11. xandertjuuuu
    Gingerbread Oct 19, 2019
    xandertjuuuu , via OnePlus 6T , Oct 19, 2019 :
    What will happen if you go Open Beta Q, and then stable Q once it's released?
  12. Charan kumar Manthena
  13. yuvraj1269
    Yeah I did. Hope this works. Thanks mate
  14. O1571365113371
  15. Danielarr45
    Danielarr45 , via OnePlus 6 , Oct 19, 2019 :
    the updater app calls it open beta 26, while OP calls it Open beta 1. I also realized the change log text is not an exact match. are these the same builds?
  16. soban_akram
  17. manasarora98
    manasarora98 , via OnePlus 6 , Oct 19, 2019 :
    Researched about it on the web, its not a bug, its Google new feature for implementing more security.
    Secondly, i request you to take your all posts down on all threads regarding this.
    Thank you.
  18. ShreeshailSU
  19. dilzit
    dilzit , Oct 19, 2019 :
    Don't forget to uninstall swift before you flash the patched boot image
