251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. SafdarHusain
    Cupcake May 18, 2020
    SafdarHusain , May 18, 2020 :
    Hello,
    I have observed following issues.... please let me know if there r potential solutions that anyone of you might have tried.....also let me know the link which can be used to report these to OP.
    1) Bluetooth connection drop frequently
    2) Mike not working for Zoom and whatsapp calls, it works post reconnecting after the call has started
    3) Whats dual app doesn't recognise the finger print and hence refuses to be locked through whats app finger print lock, had to use app locker.
    4) Hotspot doesn't support 5 gz connect anymore
    5) Microsoft SMS organiser doesn't work at all while sending messages though it shows the income ones neatly.
    G_Emad_Mosa_YIKE likes this.
  2. artur.ziraf
    Gingerbread May 18, 2020
    artur.ziraf , May 18, 2020 :
    Hi,
    Strange things happen.
    I've tried to set up ringtone from local storage (mp3 file) and after setting this file as a ringtone its disapear from local storage!
    Anyone, please help[e]1f61c[/e]
    Yours,
    Artur
  3. gauravmalik007
  4. g_tur92
    Froyo May 18, 2020
  5. sweggitity
    Ice Cream Sandwich May 18, 2020
    sweggitity , via OnePlus 5T Midnight Black , May 18, 2020 :
    The bugs I have noticed in OB2 so far...
    1. WiFi switches off in the morning, when you go to sleep for the night.
    2. when the multitasking pane is opened, the glitches for a second and shows the second app instead of the primary from where the multitask is activated.
    3. Bluetooth audio is lower when using an equilizer, I am using Equilizer Pro FX, not sure if it's app problem or Android 10, but on Android 9 the volume was fine.
    4. OnePlus Launcher is not available on the Play Store.
    R1589164796870 likes this.
  6. sweggitity
  7. meivelraja
    meivelraja , May 18, 2020 :
    After the Android 10 update I couldn't link any kind of bank accounts in Google pay,Paytm,Amazon pay apps,which I have already linked with the same mobile number in oneplus 5.. anyone kindly help me on this
    kirank04 likes this.
  8. HBP87
    HBP87 , May 18, 2020 :
    It's a known issue. What do you expect from beta builds...!!
  9. HBP87
    Use feedback please. There are no developers here.
  10. HBP87
    There's a feedback option in OnePlus Community App which can be found on the last tab.
  11. meivelraja
    Sorry,I meant that I couldn't install any app from the saved .apk file
  12. sweggitity
  13. SHVMZUTSHI
    SHVMZUTSHI , via OnePlus 5 , May 18, 2020 :
    Hi, I downloaded the open beta update for android 10 to my oneplus5 two weeks back. thought frequent wifi disconnection was an issue I was facing often from the moment I updated to android 10. This morning the mobile networks have magically disappeared. I tried swapping the sim to Sim 2 but still not able to get the network registered. Strangely all was well untill 5 hours back and all of a sudden the network dropped. I thought might be sim issue but the sim works fine in other handsets and strangely other sim is working in my handset. I am a bit confused as to if its the simcard issue or the handset update issue. Please help
  14. Bkee_Shahi
    being_nabnit likes this.
  15. chaitanya.buddaraju
  16. sweggitity
  17. Bkee_Shahi
    Bkee_Shahi , via OnePlus 5T , May 18, 2020 :
    In OB2, while calling phone mic speaker doesn't work in these both Apps.
    We can only hear another person voice but they can't hear our's.
  18. sweggitity
  19. Bkee_Shahi
    sweggitity
    It happens on speaker call?​
    What's happens?
    I didn't understand.
    But in other apps like What's App & FB Messenger mic speaker works.
    In these two apps only there is issues.
    Waiting for OB3 hope it will clear these bugs.
  20. E1522377471472
    Eclair May 18, 2020
