251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. sagarn05
    Cupcake May 18, 2020
    sagarn05 , May 18, 2020 :
    Does wifi calling work for both SIMs? Or only one sim? Currently, it is working on my OP5 only for SIM 1 when the switch is enabled. Could you please check and update. The reason why I'm asking is since OnePlus 5 does not support Dual VOLTE and if the 4g network is not available for sim2, could wifi calling work in that scenario?
  2. Ajin_Grace_Thomas
    Gingerbread May 18, 2020
  3. Waveform Modifier
    Marshmallow May 18, 2020
    Waveform Modifier , May 18, 2020 :
    All beta related comments, inquiries and complaints must be directed to the pinned beta thread only.
  4. dosse1985
    dosse1985 , May 18, 2020 :
    Do you guys get any benefit from the Optimized Charging? I have a fairly standard routine and it doesn't seem to kick in.
  5. itsprafull
    Donut May 18, 2020
    itsprafull , May 18, 2020 :
    The navigation gesture are not working perfectly some time it's get sticky and may be but battery is draning little we have 8gb ram phone and we can handle till android 11
    being_nabnit likes this.
  6. Kusai_Ghadiyali
    Froyo May 19, 2020
    cristi_lazar and anand_08 like this.
  7. nidhinnidhi
    Cupcake May 19, 2020
    nidhinnidhi , via OnePlus 5 , May 19, 2020 :
    No options to enable wifi calling after the beta updates...
    not showing it in the function switch options anymore.
    Can anybody help plz...
    thanks in advance
  8. anand_08
    Donut May 19, 2020
  9. Rohan_S_P
    Ice Cream Sandwich May 19, 2020
  10. sharadksingh
    Honeycomb May 19, 2020
  11. Ajiteshmadai
    Eclair May 19, 2020
    Ajiteshmadai , via OnePlus 5 , May 19, 2020 :
    I am facing issue with the alert slider after upgrading to Android 10 Beta 2, my phone is stuck in Silent mode.
    I did not go thru all the posts in this Thread, but on searching many others have also faced the same problem in the community.
  12. DogeAlpha
    DogeAlpha , May 19, 2020 :
    I used mine on English instead of Romanian since day 1.
    Your English is certainly above average. Or at least good enough for English UI not to bother you.
    Coming from other phones running mostly stock android (romanian language) maybe it's aosp translations.
    Digital wellbeing is Google's property so I figured you should point the finger at them for translations
    cristi_lazar likes this.
  13. Robert Uszok
    Gingerbread May 19, 2020
    Robert Uszok , via OnePlus 5T , May 19, 2020 :
    Hi all!
    Someone have same problem?
    Alarm clock not working properly - only if I set up alarm and turn off phone for few hours (5-7h, in settings "wake up phone if turned off" is checked). When I wake up phone is turned off. When I turn on have reminder that missed alarm. But today I wake up before alarm and 100% there was no alarm.
    I clean up cache and all memory at clock app. Same thing...
  14. Newbie56
    Eclair May 19, 2020
    Newbie56 , via OnePlus 5 , May 19, 2020 :
    it's a joke brother. It will come when ready of course
  15. D1589877739220
    D1589877739220 , via OnePlus 5T , May 19, 2020 :
    Go for email verification
  16. aero2
    Froyo May 19, 2020
    aero2 , via OnePlus 5 , May 19, 2020 :
    I turned on Zen mode when I was going to sleep. In the morning I rolled down status bar and then rolled up to check notifications. And after that bar disappeared and I wasn't able to turn on any app or roll down bar again. After rebot Zen mode end screen appeared and now I can use phone.
  17. Sumukh_Ananth
    Sumukh_Ananth , via OnePlus 5T , May 19, 2020 :
    Hey i have installed this new update and still my banking apps are not working, when i changed my SIM to OnePlus 6 its working but on my OnePlus 5T banking apps are unable to verify my account. Is anybody else facing the same issue?
  18. Sumukh_Ananth
    Had the issue in OB1 also, still not fixed!!
  19. DaniChan
    Donut May 19, 2020
    P1534607642563 likes this.
  20. H4yth
