251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. Md.Asif786
    Eclair May 19, 2020
    Md.Asif786 , May 19, 2020 :
    u can flash via magisk try search on xda..i am using dolby in my 1+5.
    U1531217295109 likes this.
  2. NadhuNandha
    Cupcake May 19, 2020
    NadhuNandha , via OnePlus 5T , May 19, 2020 :
    okay thanks for the reply,could you please tell me the procedure
  3. Chinmay27
    Froyo May 19, 2020
    Chinmay27 , via OnePlus 5 , May 19, 2020 :
    nope if you flash oos 10 open beta 2 and format it then you can't use any banking apps and verification if you upgrade from Android 9 and then open beta 1 and then open beta 2 then it works but for Better performance new Android version format is necessary
  4. Waveform Modifier
    Marshmallow May 19, 2020
    Waveform Modifier , May 19, 2020 :
    Install OB3 and post your future posts at the latest beta threads.
  5. mkv13
    Eclair May 19, 2020
    mkv13 , May 19, 2020 :
    open beta 3 available in Oxygen Updater
    "Note: Please disable the lockscreen security (pin/pattern/password) before updating to Open Beta 3.
    System
    • Optimized the system icons in UI of call recording, start-up animations, mobile signal, etc.
    • Fixed the bug with access to audio tuner after connecting the earphones
    • Fixed the issue with unwanted muting of calls in Google Duo
    • Fixed the bug with sending and receiving the messages while registering or activating UPI accounts
    • Improved system stability and fixed general bugs
    Camera
    • Improved the stability of camera
    Wi-Fi and Internet
    • Optimized Wi-Fi transfer speed display in network details
    • Disabled Airtel VoWiFi"
  6. Md.Asif786
    Eclair May 20, 2020
    Md.Asif786 , May 20, 2020 :
    search one plus dolby on YouTube & watch 2nd video
  7. gsthorat
    Eclair May 20, 2020
    gsthorat , via OnePlus 5T , May 20, 2020 :
    Successfully installed OB3 and no issues found so far...
    Earlier I was on stable version.
    If anyone want to install OB3 then download zip from main post. Then go to settings->System Updates-> Local update and that's it... Without any data loss.(But still make sure you take full backup )
  8. Behzadsh
    Cupcake May 20, 2020
  9. Inha1966
    Donut May 20, 2020
    Inha1966 , May 20, 2020 :
    Thanks
    Tried with Google App mic permissions off but Sleep as Android still not registering noise and snoring
  10. B1546577151419
    Cupcake May 22, 2020
    B1546577151419 , May 22, 2020 :
  11. srivinoth
  12. Waveform Modifier
    Marshmallow May 22, 2020
  13. O1526969241419
    O1526969241419 , May 22, 2020 :
    I have updated to beta 3 as of now. Can you add bottom navigation for back action, side ones are bit tricky
  14. Waveform Modifier
    Waveform Modifier , May 22, 2020 :
    This is a user community forum. Features and request goes to the feedback forum.
  15. Waveform Modifier
    Marshmallow May 23, 2020
  16. srivinoth
    Cupcake May 23, 2020
  17. Waveform Modifier
    Waveform Modifier , May 23, 2020 :
    You should look harder. It is pinned and have 600+ posts in it.
  18. srivinoth
