251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. sweggitity
    Ice Cream Sandwich May 2, 2020
  2. Negi_lokesh
    Donut May 2, 2020
    Negi_lokesh , via OnePlus 5 , May 2, 2020 :
    is it working properly on non root? android 10?
    coz when i tried back camera was fine.
    front cam was not working.
    Vince_40 likes this.
  3. mackmohan
    Froyo May 2, 2020
    mackmohan , via OnePlus 5 , May 2, 2020 :
    Google messages application is still not working. Did anyone find a workaround until this is addressed. At present, I am using the default SMS application. If archive facility is available, I don't even need Google messages.
  4. suraj_offl
    Gingerbread May 2, 2020
  5. Rohan_S_P
    Rohan_S_P , via OnePlus 5 , May 2, 2020 :
    It's jio so if we turn of volte it will not work.
  6. Ayan2710
    Deepak@1 likes this.
  7. vivek1052
    Cupcake May 2, 2020
    vivek1052 , via OnePlus 5T , May 2, 2020 :
    Ohk. I had other operator and it worked for me. Hopefully we will get this in Open beta 3
    Rohan_S_P likes this.
  8. Ayan2710
  9. Mr.Multitalented
    Cupcake May 2, 2020
    Mr.Multitalented , May 2, 2020 :
    Hello I've installed this update...
    I'm from india...
    upi is not working means the app is not sending automatically sms for upi verification... I tried all apps like phonepe ,gpay, Paytm ...but same problem persists... it was working fine before I installed this android 10 beta...
    please solve this issue ASAP.
  10. dip_to
    Cupcake May 2, 2020
  11. saishp18
    Donut May 2, 2020
    saishp18 , via OnePlus 5 , May 2, 2020 :
    is there any point for going on OB2 from OB1 since UPI apps don't work for jio and also i see many have problems with microphone etc. ???
    Shobhandana likes this.
  12. Shobhandana
  13. Tsyon
  14. sweggitity
    sweggitity , May 2, 2020 :
    Google messages is working for me, it worked on Beta 1, also on Beta 2. Not sure why you guys are facing this issue?
    Inha1966 and mackmohan like this.
  15. TeraBap
    Froyo May 2, 2020
    TeraBap , via OnePlus 5T , May 2, 2020 :
    I just observed its not playing hd or 4k videos. tried YouTube and Amazon prime videos. it's degraded to 480 resolution max
    it's not showing 720p or 1040p options. like disabled in this build?
    is it same for you guys as well?
    Muditkhanna998 likes this.
  16. mackmohan
    Froyo May 2, 2020
    You are probably lucky. 😀
    BTW, could it be related to the operator? I have a Jio sim. Just a wild guess.
  17. sweggitity
    Don't know, i suppose only Indian users are facing this issue, not international. Try to reset your phone and check if it works or not?
  18. mackmohan
    Froyo May 2, 2020
    Did that and no luck.
    I am an old time computer guy. The first thing that we all are trained to do is restart. [e]1f603[/e]
    In this case, cleared cache and tried. Thanks for your response
  19. sweggitity
    I didn't mean restart or clearing cache, but a format of all data and the phone.
  20. Muditkhanna998
