251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. Muditkhanna998
    Gingerbread May 2, 2020
  2. SubZane
    Cupcake May 2, 2020
    SubZane , May 2, 2020 :
    Problème d'autonomie la batterie se décharge très rapidement et je ne reçois pas les notifications Instagram
  3. vortex2210
    Donut May 2, 2020
    Kusai_Ghadiyali likes this.
  4. harsha.yarabarla
    harsha.yarabarla , May 2, 2020 :
    can't switch from VoWifi to Volte, it always switches back to VoWiFi even I have set Volte as preferred.
  5. reojo
    Froyo May 2, 2020
    reojo , via OnePlus 5 , May 2, 2020 :
    With TWRP
  6. ankitch
    Eclair May 2, 2020
    ankitch , via OnePlus 5T , May 2, 2020 :
    hi,
    I am on android 10 open beta 1 already. Can I download the file and install through local storage or do I again need to install through recovery which will again wipe my data?
  7. Kusai_Ghadiyali
    Froyo May 2, 2020
    Kusai_Ghadiyali , via OnePlus 5T , May 2, 2020 :
    I've noticed that too. There's no longer an option for VoWiFi on Beta 2. Also Google Messages app still keeps crashing the moment you type the 1st letter and the only way for it to work is disabling the VoLTE in settings as a workaround. Haven't tested the mic in different 3rd party apps yet. Also just the 1st charge cycle on Beta 2. Hopefully the battery backups only gets better as I already liked the backup it provided on Beta 1 anyway.
    Last but not the least,
    Thanks OnePlus Team for constantly working on the Betas on such a priority and also during this pandemic. God bless us all :)
  8. F1521649744471
    Donut May 2, 2020
    F1521649744471 , via OnePlus 5 , May 2, 2020 :
    Hello,
    Video quality was degraded by all digital platforms, YouTube, Netflix and Amazon, during lockdown. To avoid network issue because WFH.
  9. Young_Blood
    KitKat May 2, 2020
  10. Kusai_Ghadiyali
    Froyo May 2, 2020
    You can install through Local Storage option once you download the file. You might have to rename it to just have '.zip' for it to show up in the Local Upgrade and make sure it's in the Root Folder too.
    ankitch likes this.
  11. vortex2210
    Donut May 2, 2020
    vortex2210 , via OnePlus 5T , May 2, 2020 :
    I don't use Google messages, bub sms organizer...I have a jio and airtel sim...cannot send messages via the jio sim but at the same time can do it via airtel. Hopefully it gets fixed fast. My UPI and all are linked with the other sim, so I am able to run them smoothly, but many people don't.
  12. TeraBap
    Froyo May 2, 2020
    TeraBap , via OnePlus 5T , May 2, 2020 :
    F1521649744471
    Hello,
    Video quality was degraded by all digital platforms, YouTube, Netflix and Amazon, during lockdown. To avoid network issue because WFH.​
    Thanks for the reply
    I know many platform hav degraded it's default streaming to standard definition. but if someone like to see HD quality there it still had options to choose 720p & 1040p if pick manually/explicitly.
    I was able to stream 720 &1040p till yesterday before upgraded to this OB build.
    after upgrade while checking DRM app it's now showing HDR not supported.
    is it same for all?
  13. Y1513735023070
    Cupcake May 2, 2020
  14. David.Shiri
    Eclair May 2, 2020
  15. Iam ironman
    Froyo May 2, 2020
  16. SkyWreak
    Cupcake May 2, 2020
    SkyWreak , via OnePlus 5T , May 2, 2020 :
    Voice over wifi is not available in ob2 . Its was available in ob1 . anyone having same issue ?
    Also the Gap from bottom of home sceen is too large compared to oos 9 and still not rectified in ob2. 1588402727237.jpg
  17. shubham_jangra
    Donut May 2, 2020
  18. nitin_awesome
    Cupcake May 2, 2020
    nitin_awesome , via OnePlus 5 , May 2, 2020 :
    Bugs in this build:-
    1) Upi apps still not working.
    2) Alert slider has stopped working.
    3) while changing orientation in landscape mode, things are very slow and sometimes it is not there.
    4) VoWiFi option removed.
    5) using optimized battery charging feature, degrades battery life and subsequent charging speeds.
    6) boot icon in oneplus logo is reverted back to old logo.
  19. TeraBap
    Froyo May 2, 2020
