251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. miluisgood
    Froyo May 2, 2020
    miluisgood , via OnePlus 5T , May 2, 2020 :
    Strange. I don't have it in OB2.
    Corect, all are reporting different sort of problems, like I never had problem while using UPI apps.
  2. EmanueleFulco
    Honeycomb May 2, 2020
    EmanueleFulco , via OnePlus 5T , May 2, 2020 :
    UPI apps are banking services in India? Or global banking services? Because mine (Italians) works well, and I can also pay with nfc, tried 2hrs ago.
  3. Makova
    Jelly Bean May 2, 2020
  4. gowthammotox
    gowthammotox , May 2, 2020 :
    no, update as local update
  5. Sree321
    Donut May 2, 2020
    Sree321 , via OnePlus 5 , May 2, 2020 :
    Hello everyone I have installed this beta 2 and so far no bugs faced till now
    1. Upi is working perfectly
    2. battery consumption is reduced compared to open beta 1
    3. all wifi, bt are working fine.
    4. overall system animation much more refined than ob 1
    I'm rooted with magisk and safety net is also working fine
  6. hjs2396
    Gingerbread May 2, 2020
    hjs2396 , via OnePlus 5T , May 2, 2020 :
    updated from stable to beta this morning
    after installation did a clean wipe of data
    smooth ui
    missing OnePlus gestures but have to adjust to the new gestures
    had no issues with vowifi volte toggles
    the empty space in the bottom annoys me
    had to register upi after disabling volte and vowifi toggles
    and back gesture seems to be unresponsive sometimes
    Marek S. likes this.
  7. krishnaE
    Froyo May 2, 2020
    krishnaE , via OnePlus 5T , May 2, 2020 :
    I don't think you are on jio network
  8. hjs2396
  9. krishnaE
    Froyo May 2, 2020
  10. hjs2396
  11. miluisgood
    Froyo May 2, 2020
    Yes, these are unified payment apps. As far as I know, only available in India.
    EmanueleFulco likes this.
  12. krishnaE
    Froyo May 2, 2020
    in jio by turning off volte doesn't send message because like airtel they do not have 2g or 3g spectrum.in airtel if you turn off volte the message will be sent by 2g band.
  13. miluisgood
    Froyo May 2, 2020
  14. Hariharan_k
    Cupcake May 2, 2020
    Hariharan_k , May 2, 2020 :
    UPI registration is not working in the current build too. We cannot use most of the banking and finance apps.
  15. DogeAlpha
  16. dileep6824
    Cupcake May 2, 2020
    dileep6824 , May 2, 2020 :
    hi too much battery drain after updated to android 10
    please fix this problem ASAP
  17. Makova
  18. SurajLoharia
    KitKat May 2, 2020
    SurajLoharia , via OnePlus 5 , May 2, 2020 :
    A10 have robust security
    would suggest you to kindly remove any password/pattern/PIN before accessing recovery.. till the STABLE
  19. miluisgood
    Froyo May 2, 2020
    Yeah. Highly secured.
