251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. prashanthip
    Cupcake May 2, 2020
    prashanthip , via OnePlus 5T , May 2, 2020 :
    turn off volte and wifi calling and try it
    it worked for me
    I hope it will work on ur phone
  2. NEERAJ MISHRA
    Cupcake May 2, 2020
  3. kukreja360@gmail
    Cupcake May 2, 2020
  4. C1520910424093
    Froyo May 2, 2020
    C1520910424093 , May 2, 2020 :
    But first i backup data with oneplus switch first right?
  5. paulomodesto
    Jelly Bean May 2, 2020
    paulomodesto , via OnePlus 5T , May 2, 2020 :
    I've noticed it to, but launcher stills on play store, it is only not available for install, I guess it's because the OnePlus 5/5T is registered to have Android 9.
    Android 10 it's on test so no one can install it from PlayStore.
    https://play.google.com/store/apps/details?id=net.oneplus.launcher
    Have installed and current running version 4.4.2 from APKMirror to.
    Sandrine5T and Evgeny.S like this.
  6. hbvishnu
    Froyo May 2, 2020
    hbvishnu , via OnePlus 5T , May 2, 2020 :
    5T , u will find 5T or 5 in download link
  7. Navinmholkar
    Gingerbread May 2, 2020
  8. hbvishnu
    Froyo May 2, 2020
    actually I didn't reset. I didn't have problem too. u can backup with switch. Post the installation if you have problem with loading atleast 3 to 4 minutes, delete data in recovery mode
  9. kukreja360@gmail
    Cupcake May 2, 2020
    hbvishnu likes this.
  10. CMiles1979
    Cupcake May 2, 2020
    CMiles1979 , via OnePlus 5T , May 2, 2020 :
    I updated successfully from beta 1 to beta 2 and have to admit that it is smoother and I'm happy not going back to Android 9.
    I don't know if it is a bug, but on YouTube the buttons wont disappear.
  11. mano0506
    Cupcake May 2, 2020
    mano0506 , May 2, 2020 :
    Same problem for me too bro. If u get any solution pls say me. Tis s ma no :9710300607
  12. Power User M4
    Froyo May 2, 2020
    the_dalvik_cache likes this.
  13. reyscott1968
  14. ganesh1228
    Cupcake May 2, 2020
  15. W1514291170976
    Donut May 2, 2020
    W1514291170976 , May 2, 2020 :
    Chill out man!! I asked if the battery drain is lesser compared to the first beta, if u don't have an answer then ignore the message. 🤦‍♂️🤷
  16. dileep6824
    Cupcake May 2, 2020
    dileep6824 , May 2, 2020 :
    what's your problem ??do you have any suggestions let me know or else leave it
  17. Bishal Kanti Roy
    Eclair May 2, 2020
  18. RedBandanaSissel
    Eclair May 2, 2020
    RedBandanaSissel , via OnePlus 5T , May 2, 2020 :
    Read the filename. It clearly says 5T in there. The links were fixed soon after the users started reporting they were interchanged.
  19. gsuklecha
    Froyo May 2, 2020
    gsuklecha , via OnePlus 5 , May 2, 2020 :
    Doesn't look like that because oneplus launcher was available on play store when i first installed beta1. It was stopped showing in play store since 1st may.
    Before that it was showing with android 10 on oneplus 5 as well
  20. saiSumanth1+
    Honeycomb May 2, 2020
    saiSumanth1+ , via OnePlus 5T , May 2, 2020 :
    vowifi is working with single sim,if we add single sim ,then the option (vowifi) is available in settings,and if we add dual sim then the option is simple fade away
