251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. chamikararx
    Cupcake May 2, 2020
  2. E1526749009371
    Donut May 2, 2020
    chamikararx likes this.
  3. Mehmet_Ali
    Froyo May 2, 2020
  4. srkrms
    Cupcake May 2, 2020
  5. Sid_Ck
    Ice Cream Sandwich May 2, 2020
    Sid_Ck , via OnePlus 5T , May 2, 2020 :
    Yes..
  6. P1512569276852
    Gingerbread May 2, 2020
  7. Sid_Ck
  8. srkrms
    Cupcake May 2, 2020
  9. Sid_Ck
    I have wifi calling option on this update too
  10. Sid_Ck
    Most likely, as I don't think ota for stable will wipe the data. I'm not sure tho
  11. Sid_Ck
    Yes u do
  12. redone
    Donut May 2, 2020
    Marek S. likes this.
  13. H1570254960121
    Cupcake May 2, 2020
    H1570254960121 , via OnePlus 5T , May 2, 2020 :
    I have the android 10 beta 1 already installed. I have donwloaded the beta 2 and moved the file to the root directory. When i go to software update and local upgrade, i cant find the install package. Please help me with this
  14. eng.3omda
  15. Akshay V Anil
  16. mmrtnt55
    Cupcake May 2, 2020
    mmrtnt55 , via OnePlus 5T , May 2, 2020 :
    Remove the .jar extension from the file.
  17. anandsiddharth
    anandsiddharth , via OnePlus 5 , May 2, 2020 :
    Remove the .jar extension from the file name, and make sure that it's .zip and it'll work
  18. HBP87
    HBP87 , via OnePlus 5 , May 2, 2020 :
    You need to rename the extension from .jar to .zip
  19. Kusai_Ghadiyali
    Froyo May 3, 2020
    Kusai_Ghadiyali , via OnePlus 5T , May 3, 2020 :
    Which region and what network provider?
    I'm using a 5T too and on Jio network which had VoWiFi on Beta 1 but no longer see it on Beta 2.
  20. sharadksingh
    Honeycomb May 3, 2020
    sharadksingh , via OnePlus 5T , May 3, 2020 :
    Remove .kar extension.
