251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. petersurfs
    Froyo May 1, 2020
    petersurfs , May 1, 2020 :
    EmanueleFulco
    So click on OnePlus 5T download
    It is OnePlus 5 Rom, you can see the name while downloading​
    I'm download the link which was just given and it still says 5t
    #41
  2. EmanueleFulco
    Honeycomb May 1, 2020
    EmanueleFulco , via OnePlus 5T , May 1, 2020 :
    In fact it is 5T rom
    Click on Oneplus 5T link in the original post. It will download OP5 rom.
    #42
  3. AungShinnthant
    Cupcake May 1, 2020
    #43
  4. vip+1
    Froyo May 1, 2020
    vip+1 , via OnePlus 5 , May 1, 2020 :
    is there any data loss?
    #44
  5. C1520910424093
    Froyo May 1, 2020
    C1520910424093 , May 1, 2020 :
    LOL downloaded from that 5T link and unable to install. Have to re-download from 5 link for correct file.
    #45
    AbhilashSaikia likes this.
  6. dsmonteiro
    Community Consultant Staff Member May 1, 2020
    Stickied Post
    dsmonteiro , May 1, 2020 :
    Users who are still on OBT builds for 5/5T can update to this build only via update from recovery. For those, PLEASE NOTE, your entire data will be wiped.
    • Turn off the device -> Press power and volume up key simultaneously until the device enters the Fastboot Mode
    • Navigate to Recovery option using volume and power button -> Choose English -> Install from Internal storage -> Select the downloaded zip file -> Select 'Yes'
    • Wait until the installation is complete -> Reboot
    Note:
    1. OnePlus Switch cannot back up data stored in lockbox,
    it is recommended to move the lockbox data out or save it to other equipment to avoid data loss.
    2. After this update, the backups from OnePlus Switch may not show up. You can fix this issue by updating to the latest OnePlus Switch version from the play store.
    3. Please keep in mind that this is beta software. These builds are not as stable as our official OTAs. By installing this update, you accept the potential risks. As always, please share your feedback through https://forums.oneplus.com/feedback/. For more information on submitting bugs or suggestions please refer to How to report a bug and feel free to share your product suggestions via the Community app
    If you don't have the Community app installed on your device, feel free to download it HERE. You can check here for more information on the integrated Feedback tool. Make sure to let us know how you feel about the build here in the thread too, we look forward to reading your feedback.
    Never Settle.
    #46
    ichereda, Tonyxus, hoanbt and 33 others like this.
  7. EmanueleFulco
    Everything will be ok, datas will rest in your memory! Don't worry.
    You'll lose datas only if you came from an old BETA based on android 9.
    #47
  8. David.Shiri
    Eclair May 1, 2020
    David.Shiri , via OnePlus 5 , May 1, 2020 :
    Alexxer201
    I can't update. I'm on Beta 1 and after moving the correct build to root directory it doesn't appear as an available local upgrade. Waiting for the fix. [e]1f60a[/e]​
    you need change name to .zip
    #48
    caesarivs, devansh2, aero2 and 2 others like this.
  9. EmanueleFulco
    #49
    Nikkhil, vksinha, aero2 and 4 others like this.
  10. AlloTomato
    #50
  11. joelshawdow
    Eclair May 1, 2020
    joelshawdow , via OnePlus 5 , May 1, 2020 :
    C1520910424093
    LOL downloaded from that 5T link and unable to install. Have to re-download from 5 link for correct file.​
    what is the name of the downloaded file
    is this for op5?
    #51
  12. dsmonteiro
    Links are fixed, thanks for the heads-up.
    Hi @Some_Random_Username,
    Unfortunately that will not be the case, due to how the beta builds are set up. Stable build will still be pushed as a OTA update, though.
    #52
  13. C1520910424093
    Froyo May 1, 2020
    I think they have fixed the download link now. You can download according to your device model.
    #53
    dsmonteiro likes this.
  14. EmanueleFulco
    #54
  15. #55
  16. AlloTomato
    AlloTomato , via OnePlus 5 , May 1, 2020 :
    I tried by removing .jar extension , failed to detect the forward file in updater
    #57
  17. 27itachi
    27itachi , via OnePlus 5T , May 1, 2020 :
    No you won't have any data loss it's just like an update nothing much ...
    #58
    Savio111, MostakimShohan and vip+1 like this.
  18. Pierre02
    #59
    gopalan_md19 likes this.
  19. C1520910424093
    Froyo May 1, 2020
    Correct me if I am wrong. According to the youtube tutorial you should rename the file to .zip
    #60
    Aamir Aman, gopalan_md19 and Davids1 like this.
