251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. Shubham Gujjar
    Honeycomb May 3, 2020
    Shubham Gujjar , via OnePlus 5T , May 3, 2020 :
    new glitch i found when I'm playing PUBG Mobile and starting recording My teammate can't hear me also when i stop recording. i face this problem another Apps also.
    Only way to fix this close all apps in recent then sometime it's work not 100% work.
  2. D1581868789335
    Cupcake May 3, 2020
  3. rahulkr.ver
    Gingerbread May 3, 2020
    rahulkr.ver , via OnePlus 5 , May 3, 2020 :
    After this beta 2 updated of oneplus 5.
    i Am facing heating issue , without using any application, ..
    if you are using open beta 1 , then do not upgrade to open beta 2 .
    open beta 1 is working fine.
  4. J1513095112497
    Donut May 3, 2020
    J1513095112497 , via OnePlus 5T , May 3, 2020 :
    my query has been solved as the links are inverted I have downloaded the wrong file I think that was the reason it is not showing in the local upgrade 😅
  5. sharadksingh
    sharadksingh , via OnePlus 5T , May 3, 2020 :
    remove .jar extension because it has already .zip extension.
  6. J1513095112497
    Donut May 3, 2020
    Yes I have removed the jar extension and even mentioned in my comment
  7. rahulkr.ver
    rename those file , remove ( .jar) extension
    after rename (file name.zip) only show.
    move your file in root directory (directly move into internal storage , not in folder)
    done[e]1f44d[/e]
  8. J1513095112497
    Donut May 3, 2020
    I did that bro but still I can't see the file
  9. rahulkr.ver
  10. rahulkr.ver
  11. J1513095112497
    Donut May 3, 2020
  12. rahulkr.ver
  13. J1513095112497
    Donut May 3, 2020
    bhai ho gaya actually maine wrong file download kara 😅
  14. Ravi Soni 1993
    Froyo May 3, 2020
    J1513095112497 likes this.
  15. J1513095112497
    Donut May 3, 2020
    ha bhai check kar liye apna Jo bole wo sahi hai aur is pehle mainey rectify kar liya
  16. karthik yadawad
    Ice Cream Sandwich May 3, 2020
    karthik yadawad , via OnePlus 5 , May 3, 2020 :
    Go to developer options enable advanced reboot, hold your power for 2 sec it should appear. unlock your device, then choose install from internal storage.
    before proceeding change the file extension, remove .jar
  17. Abhinavkk
    Eclair May 3, 2020
    Marek S. likes this.
  18. Y1521353080546
    Cupcake May 3, 2020
  19. J1513095112497
    Donut May 3, 2020
