251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. J1513095112497
    Donut May 3, 2020
    J1513095112497 , via OnePlus 5T , May 3, 2020 :
    thanks bro
  2. Guilherme_Scheuer
    Cupcake May 3, 2020
  3. Rohan_S_P
    Ice Cream Sandwich May 3, 2020
    Guilherme_Scheuer likes this.
  4. tazd
    Eclair May 3, 2020
    tazd , via OnePlus 5 , May 3, 2020 :
    it's a .jar instead of .zip when trying to download for OP5, am i missing something ?
    edit:fixed it using above suggestions, sorry to repost before checking.
  5. RM18
    Cupcake May 3, 2020
  6. tazd
    Eclair May 3, 2020
    split screen still not working as intended, I'm not sure what exactly was optimized?
    it only works if screen is rotatable from vertical to horizontal or vice versa.
    kindly fix it in the next update.
  7. hjs2396
    Gingerbread May 3, 2020
  8. pinto123
    Honeycomb May 3, 2020
    g_tur92 likes this.
  9. pallabgupta
    Cupcake May 3, 2020
  10. g_tur92
    Froyo May 3, 2020
    g_tur92 , via OnePlus 5T , May 3, 2020 :
    You can check the active processes in Memory Section, you can find it in Developer settings. You can use app inspector to find the package name for every single app installed on your device.
    Anyway you can find many guides on Xda explaining which packages you can safely delete/disable and which you should keep. Just search "debloat oxygen os"
  11. hjs2396
    hjs2396 , via OnePlus 5T , May 3, 2020 :
    thank you
    g_tur92 likes this.
  12. Sivaganth
    Cupcake May 3, 2020
    Sivaganth , May 3, 2020 :
    Hello, when I try to install the package, it says my current version is lower than the downloaded package. Not sure why. Please see the screenshots of my current version and the package I downloaded. Did I download very old package?
    It also tells me to go via recovery mode.
    Please someone advice
  13. David.Shiri
    Eclair May 3, 2020
    David.Shiri , via OnePlus 5 , May 3, 2020 :
    contacts cant be found on manually search...but apper on the phone (google contacts ) after restarting its working ,but after awhile again....
    did cash clean but nothing....just this bug !!
  14. madhav_taparia
    Cupcake May 3, 2020
    madhav_taparia , via OnePlus 5 , May 3, 2020 :
    Hey Team! Thanks for this awesome build. I'm in love with my OnePlus 5 all over again!
    I installed it couple hours ago and everything seems good. Just one thing I noticed which I feel is odd.
    Holding the back button shows the background running apps but the app stills appear at a higher level than normal (probably leaving the space for in-display buttons at the bottom). Please fix this too amongst other things. Thanks!
  15. Marleyfan61
    Froyo May 3, 2020
    Marleyfan61 , May 3, 2020 :
    It's on the very first page of this thread. If you're waiting for an OTA update it's not gonna happen. A very small amount of reading first and you could have answered your own question.
  16. bala@9605
    Donut May 3, 2020
    bala@9605 , May 3, 2020 :
    While using vodafone sim data my HDFC banking app &IDBI bank app not opening ...instead of using jio every thing fine ..anybody facing this issue ??
    abhinavkakku likes this.
  17. F_Jitu_Chawla_gxli
    Cupcake May 3, 2020
  18. olly2009
    Eclair May 3, 2020
    olly2009 , May 3, 2020 :
    Bug report: I have a glitch with split screen: I assigned the split screen shortcut to 'double tap return' and while it switches to split screen mode, the split remains hidden at the bottom : I have to move up to display the split, while on Android 9 the split would automatically move up to the middle of the screen.
  19. Pratik2299
    Froyo May 3, 2020
    Pratik2299 , May 3, 2020 :
    guys, some of the users including me was/are facing the problem for auto call recording feature after the new update. it was not showing up in many devices. if you are using dual sim then try to activate it deactivate the secondary sim from the settings-> sim & network. that's it, the call recording function will appear.
  20. G_nagabharath_vemuri_ECa
    Cupcake May 3, 2020
