251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. B_Wrath
    Nougat May 4, 2020
    B_Wrath , May 4, 2020 :
    I don't understand how you linked it to the phone, chipset and ram. M audio keystation should work on it. While other midi keyboard are working, if it isn't working, then take it up with them.
  2. W1554647118636 , via OnePlus 5T Midnight Black , May 4, 2020 :
    Bugs were already reported on 9 pie a year ago. After a year they came up with a useless 10 update which has even more bugs with broken bottom of keyboard.
    I tried this update to check if any of previous issue are fixed buy there are more.
    Do you work for one plus?
  3. T1511940147666
    Froyo May 4, 2020
    Deactivated User likes this.
  4. Deactivated User
    May 4, 2020
    T1511940147666 likes this.
  5. W1554647118636 , via OnePlus 5T Midnight Black , May 4, 2020 :
    Are you serious dude?
    Check the bugs i reported. I posted a video where old phones are running keystation and 5t is freezing. Its not maudios fault. OTG is useless. You even don't have drivers for x box controllers which i use for modulation.
    Do u work for OP?
  6. B_Wrath
    Nougat May 4, 2020
    I don't work for OP.
    Answer me this. If other midi keyboards are working with 5T, why isn't the m audio not working? It might be a problem from their end too.
  7. Deactivated User
    May 4, 2020
  8. I1588227570930
    Donut May 4, 2020
  9. markini
    Nougat May 4, 2020
    markini , May 4, 2020 :
    no
  10. Malhotra_H
    Cupcake May 4, 2020
    Malhotra_H , via OnePlus 5T , May 4, 2020 :
    Unable to perform this function after downloading the data and going to recovery mode,I'm not getting the loaded file there and when I start my mobile back it is showing the loaded file,What to do I'm on Open beta 1
  11. sachu0709
    Eclair May 4, 2020
    sachu0709 , via OnePlus 5T , May 4, 2020 :
    yes it is with every 5t device but i think it is for that navigation capsule to work if the space will he not there then it become difficult to use that capsule down in Middle.
  12. im.ashish
    Honeycomb May 4, 2020
    im.ashish , via OnePlus 5T , May 4, 2020 :
    already disabled the capsule... I don't want it to visible, gesture works with nova
  13. Rohan_S_P
    Ice Cream Sandwich May 4, 2020
  14. Deactivated User
    May 4, 2020
    Malhotra_H likes this.
  15. Malhotra_H
    Cupcake May 4, 2020
  16. Deactivated User
    May 4, 2020
  17. Navdeep_Malik
    The Lab Reviewer - OnePlus TV U1S May 4, 2020
    Behzadsh likes this.
  18. Behzadsh
    Cupcake May 4, 2020
    Behzadsh , May 4, 2020 :
    I read somewhere that unlike android 9 beta program, we can update from this beta program to stable Oxygen OS 10 (when it comes), without wiping data. Is that correct?
  19. sachu0709
    Eclair May 4, 2020
    yew u can disable the capsule by going in the settings too without using any launcher or anything else but the space downside there still exist to use the gesture effectively.
  20. Romanelo
    Gingerbread May 4, 2020
