251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. 350Rocket
    Froyo May 6, 2020
    350Rocket , via OnePlus 5 , May 6, 2020 :
    on the XDA thread it's been asked multiple times but nobody knows. I'd really like if I could just flash it through local storage. I used to mess around and install custom ROMs until I got this phone, I just don't see the point anymore until software support is dropped at least.
  2. ycbilsel
    Cupcake May 6, 2020
    ycbilsel , May 6, 2020 :
    i just updated to ob2 from latest open beta of android 9. my first impressions are battery drains faster and charging is definitely takes longer. also have some Bluetooth connection problems with mu honor band 5. rest is nearly same with android 9 based latest open beta.
  3. haymay7g
    Cupcake May 6, 2020
    haymay7g , via OnePlus 5 , May 6, 2020 :
    Hi
    Please see screenshot of my current system software.
    Please guide me as to how I may update my OP5. Please use simple language. Thanks
  4. petersurfs
    Froyo May 6, 2020
    petersurfs , May 6, 2020 :
    go to settings and change update method to android q beta
  5. Kusai_Ghadiyali
    Froyo May 6, 2020
    Kusai_Ghadiyali , via OnePlus 5T , May 6, 2020 :
    Can you check if it's working with headphones or any bluetooth audio devices connected with any third party apps apart from WhatsApp?
  6. haymay7g
    Cupcake May 6, 2020
    Thanks. I've done that. What next. Forgive me for appearing very hesitant because
    I once had an extremely bad experience with an update.
  7. haymay7g
    Cupcake May 6, 2020
  8. Shobhandana
    Gingerbread May 6, 2020
  9. gvndmittal93
    Donut May 6, 2020
  10. SiddharthBokaria
  11. SiddharthBokaria
    SiddharthBokaria , via OnePlus 5T , May 6, 2020 :
    Go to recovery by switching off phone and holding vol up + power button. Fastboot will come up, here navigate using volume keys and select recovery option using power button. In recovery menu go to wipe data. Do a total wipe of all system data and cache. Restart the phone it'll be fixed.
  12. karthik yadawad
    Ice Cream Sandwich May 6, 2020
  13. SiddharthBokaria
    I did, it was working fine in beta 1, none the less OnePlus has accepted that it's a bug and will be fixing it in beta 3 so let's just wait and watch for now.
  14. karthik yadawad
    karthik yadawad , via OnePlus 5 , May 6, 2020 :
    yup!
  15. UditPokhriyal
    Eclair May 6, 2020
  16. samyakjain552
    Eclair May 6, 2020
    samyakjain552 , via OnePlus 5T , May 6, 2020 :
    I downloaded the zip file and moved it to the root directory but unable to find it in the local upgrade section. I'm currently on android 10 open beta 1.
  17. tarunjuneja
    Cupcake May 6, 2020
    tarunjuneja , May 6, 2020 :
    Thanx a Ton. I am now back to Android 9. Will wait for the stable version of Android 10. Just had the glimpse of it with Beta 2. I have found interesting new features into it. Eagerly waiting for the final now.....
  18. Sid_Ck
    Sid_Ck , via OnePlus 5T , May 6, 2020 :
    Nope I still have the wifi calling option in Open Beta 2
  19. UditPokhriyal
    Eclair May 6, 2020
    UditPokhriyal , via OnePlus 5T , May 6, 2020 :
    How did you have it bro?
    I had Local Upgraded my Oneplus 5t from open beta 1 to 2.
    Then I found that the boot oneplus logo had reverted back to original old one instead of new oneplus logo but powered by android logo (new one) is still there.Wifi calling feature is removed in mine.
  20. UditPokhriyal
    Eclair May 6, 2020
    Bro. have you removed the .jar extension?
