251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. 350Rocket
    Froyo May 8, 2020
    350Rocket , via OnePlus 5 , May 8, 2020 :
    I tried a clean install and it caused more problems than it fixed. it was actually running better on the dirty install. I'm not the only one with the microphone problem, so I'm just going to have to wait for the update to fix it and carry a second phone for now.
  2. GauravParashar
    Cupcake May 9, 2020
  3. yowhatup
    Froyo May 9, 2020
    yowhatup , May 9, 2020 :
    I just upgraded and Hangouts and Messages crashes when I start typing. Any ideas?
    gdwhitehouse likes this.
  4. yowhatup
    Froyo May 9, 2020
    Did that and also booted into recovery and wiped cache, but didn't work.
  5. Irish007
    Cupcake May 9, 2020
    Irish007 , via OnePlus 5T , May 9, 2020 :
    yes
  6. Irish007
    Cupcake May 9, 2020
  7. Chinmay27
    Froyo May 9, 2020
  8. Irish007
    Cupcake May 9, 2020
  9. karthik yadawad
    Ice Cream Sandwich May 9, 2020
    karthik yadawad , via OnePlus 5 , May 9, 2020 :
    only JIO network have problems to verify device, apart from this everything works fine
    SandeepRana29 likes this.
  10. karthik yadawad
  11. karthik yadawad
  12. SandeepRana29
    Donut May 9, 2020
    SandeepRana29 , via OnePlus 5T , May 9, 2020 :
    Thankyou oneplus. You guys just Rocks.
    But jst one complaint regarding experience of your last android built for oneplus 5t android 10.. the new navigation gestures are not working smoothly.
    but in this beta 2, i think their is some improvement you have done. I hope in next update you guys will totally fix it.
    Weldon Guy's
  13. 047mukti@gmail.c
    Eclair May 9, 2020
    047mukti@gmail.c , May 9, 2020 :
    Facing problem for UPI link
    other mobile easily linked my account but this Oxygen OS beta 2 cannot do it.
  14. sachkharb
    sachkharb , May 9, 2020 :
    submit bug report
  15. Kusai_Ghadiyali
    Froyo May 9, 2020
    Kusai_Ghadiyali , via OnePlus 5T , May 9, 2020 :
    You'll have to disable the VoLTE and VoWiFi for those apps to work. It's a bug in these betas and should be possibly fixed on the upcoming versions.
    A1511276098442 and Shobhandana like this.
  16. GauravParashar
    Cupcake May 9, 2020
    GauravParashar , May 9, 2020 :
    can you please elaborate it
    Shobhandana likes this.
  17. karthik yadawad
    download the build, remove .jar file extension extension or rename the downloaded build to .zip. Enable advanced boot menu in developer options, then back up your data, hold the power button then toggle recovery mode..
    unlock your device select install from internal storage. hope this helps.
  18. ajayojhaca
    Cupcake May 9, 2020
  19. GauravParashar
    Cupcake May 9, 2020
    ok thanks will try it
