251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. VictorBJr
    Cupcake May 9, 2020
    VictorBJr , May 9, 2020 :
    Thanks! I've been trying to figure this out for over a week. Don't know how you figured it out but I'm glad you did! Kudos!
    Shobhandana likes this.
  2. gdwhitehouse
    Donut May 9, 2020
    gdwhitehouse , via OnePlus 5T , May 9, 2020 :
    I have this as well, can't send SMS from Google Messages. Cleared both caches and restated, no difference.
    Tried a different keyboard and that crashed too, so thinking it is to do with Messages.
    Mjain12 likes this.
  3. christophedcosta
    Eclair May 9, 2020
    christophedcosta , via OnePlus 5 , May 9, 2020 :
    seems like the carrier is blocking it. I'm facing the same issue.
  4. gdwhitehouse
    Donut May 9, 2020
    Just managed to resolve this by uninstalling Messages and then reinstalling...
    Not sure if that helps anyone else...?
  5. AhtishamQ
    Cupcake May 9, 2020
    AhtishamQ , May 9, 2020 :
    Unfortunately with this upgrade the Botim outgoing call microphone 🎤 is not working. I can hear the other party but they can't hear me
  6. UditPokhriyal , via OnePlus 5T Midnight Black , May 9, 2020 :
    Bro, In screenshot 3 - Override Force Dark-Mode is a developer option used for those apps who don't have a dark mode or in simple words,it just adds a dark-gray gradient to all apps(who don't support dark mode)
    Kusai_Ghadiyali likes this.
  7. sysara
    Donut May 9, 2020
    sysara , via OnePlus 5T , May 9, 2020 :
    I'm on open beta 2 only.. WiFi calling is available for me
  8. sysara
    Donut May 9, 2020
    updated from beta 1 only
  9. bsk.madhavi@gmai
    Gingerbread May 9, 2020
    bsk.madhavi@gmai , via OnePlus 5T , May 9, 2020 :
    looks like sms issue should be resolved in next build as stated by Oneplus support team
  10. BadMama
    Cupcake May 9, 2020
  11. Azeeb_IND
  12. Gurunath Gupta
    Cupcake May 9, 2020
  13. CHANND
    Donut May 9, 2020
    CHANND , via OnePlus 5 , May 9, 2020 :
    FIX: those who are experiencing issues with bank apps activation (UPI), disable the Wi-Fi calling in settings and try.
    my activation process started after disabling Wi-Fi calling and VoLTE .
    hope this helps! :)
  14. CHANND
    Donut May 9, 2020
    disable Wi-Fi calling and VoLTE and try. after successful activation, enable them
  15. kingsukpasari
    Cupcake May 9, 2020
    kingsukpasari , via OnePlus 5T , May 9, 2020 :
    no it does not work on Headphones either. I found a fix though, just deny microphone permission to google app before using any video calling app, it will work, somehow system is not able to use microphone while using all those apps as it is being continuosly used by Google app, whereas there is no issue while using whatsapp calling, but I tried to search something in Google while video calling in whatsapp, the same problem is there again, other person can't hear anything. These are all bugs, should be fixed in next beta or the stable one.
    G_Emad_Mosa_YIKE likes this.
  16. 350Rocket
    Froyo May 9, 2020
  17. Ilshat.Ishdavlet , via OnePlus 5T , May 9, 2020 :
    Mjain12 likes this.
  18. aero2
    Froyo May 9, 2020
    aero2 , via OnePlus 5 , May 9, 2020 :
    Hi
    I like this OxygenOS 10, but sometimes I'm getting lags or weird apps acting. I'm getting these when I have some apps running in a background like an Instagram or an Tidal and I want to open them fast after unlock phone. They're opening blank sometimes and I have to wait about 5-6s for them to back to normal or I have to close them. Besides that, system seems to me more laggy than OxygenOS 9. I performed cache erase but maybe does it better would be to fresh install this beta?
