251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. Funk Wizard
    Moderator Moderator May 12, 2020
    Funk Wizard , May 12, 2020 :
    All beta related issues should be discussed on the release thread. I will merge it to the appropriate thread for you to continue discussion, Thanks
  2. L1508267744593
    Cupcake May 12, 2020
  3. manish.ecol
    manish.ecol , via OnePlus 5 , May 12, 2020 :
    This is just experience sharing. Updated from 9.11 to OB 1 and then OB2 through local upgrade. The battery life was surprisingly better in OB1 than OB2, although the charging time seems to have increased (perception only).
    Like others, facing issues of:
    1. Banking app login fails with jio Sim (eagerly waiting a fix or if anyone has found a work around for jio Sims).
    2. Microphone issue. Person on the other end of a voice call reports very low audible volume.
    3. Wifi calling option is missing (was present in OB1).
    4. Can't find back gestures on screen.
    Otherwise the UI experience is great & thank you OP for keeping their promise.
  4. DogeAlpha
    Honeycomb May 12, 2020
    DogeAlpha , May 12, 2020 :
    You should receive further OTAs for betas and when stable gets released you'll either get an OTA, either you will have to install it manually (but you won't lose any data anyway as far as I know)
    vivthegod likes this.
  5. boscosoans
    boscosoans , May 12, 2020 :
    Hey guys, is there a possibility to rollback to Android 9? I don't care about the wipe and all. It's all backed up. I just want to know if there is a specific file I could use, or just the last stable 9.0.11? This may have been asked in the previous pages of this thread but there's obviously 90 pages and no option to search this thread specifically. Also, if this procedure exists, can it be added to the OP so that people can read it first-off.
  6. B1523596431154
    Gingerbread May 12, 2020
  7. I1517068557818
    Eclair May 12, 2020
    Rohith Reddy007 likes this.
  8. shahbaj alam
    shahbaj alam , via OnePlus 5T , May 12, 2020 :
    it's very simple .. just download 9.0.11 from OnePlus website, place the zip file in root folder, go to system update>local upgrade>select the zip file and flash it .... welcome to pie..
    boscosoans likes this.
  9. gsthorat
    Eclair May 12, 2020
    gsthorat , via OnePlus 5T , May 12, 2020 :
    Hi many thanks for the quick turnaround on this.
    Sorry but I couldn't find Wifi calling option in my oneplus5t phone. I searched on google and even I tried the Onepluslogkit to enable that but couldn't find that option there as well.
    Second problem is if I disable the volte l am not getting any sms/call because l am using Jio sim card.. :(
    Thanks
  10. HalCapone
    HalCapone , May 12, 2020 :
    Yes you can just download the pie build boot in to recovery and you can do it.
    Here is the link
    https://www.oneplus.com/uk/support/softwareupgrade/details?code=PM1574156155944
  11. HalCapone
    Ask in the 8 pro thread. Someone may be able to get the tone using file manager and send it or upload it for you
    g_tur92 likes this.
  12. 350Rocket
    Froyo May 12, 2020
    350Rocket , via OnePlus 5 , May 12, 2020 :
    for me it was the regular phone app wouldn't work on speakerphone. I denied Google app permissions to the microphone and that fixed it. It was posted by other people having microphone issues with various apps.
  13. HollowYears
    HollowYears , May 12, 2020 :
    there is an irritating problem when opening appdrawer. when swiping up to open the drawer sometimes search bar appears instead of apps list. if you holding your finger a little more than usual when swiping up, it happens. cant find any settings about it sadly.
    anksjdhv likes this.
  14. 350Rocket
    Froyo May 12, 2020
    Has anyone confirmed it's safe to do? I have seen lots of people ask and nobody confirm it will work. I was about to do it and it warned me it could fail to boot because of installing an older version.
  15. Pierre02
    Pierre02 , May 12, 2020 :
    It works fine without any alert from 9.0.11
  16. G_Rupesh_Sah_xnUv
    G_Rupesh_Sah_xnUv , via OnePlus 5 , May 12, 2020 :
    thank you [e]1f60a[/e][e]1f60a[/e]....
    worked for me too..
    hope that issue would be fixed in stable release.
    350Rocket likes this.
  17. G_Shahid_Ummer_dbrV
    Froyo May 12, 2020
    G_Shahid_Ummer_dbrV , May 12, 2020 :
    I am running Open Beta 2 (Android 10) on my OnePlus 5T.
    In the YouTube app, channels I have already subscribed to show as not subscribed. And it I click subscribe and visit the channel again (without quitting the app too) it again shows as not subscribed.
    Anyway to fix this?
  18. g_tur92
    Froyo May 12, 2020
    Abhinavkk likes this.
  19. swapnil.srele
