251
OxygenOS Android 10 Open Beta 2 for OnePlus 5/5T
  1. riozero96
    Eclair May 12, 2020
    riozero96 , May 12, 2020 :
    Mustasim
    no dear. unfortunately this is the last version. i guess.​
    i hope dev team will surprise us
  2. berktjah
    Gingerbread May 12, 2020
    berktjah , via OnePlus 5T , May 12, 2020 :
    they barely delivered android 10. android 11 not gonna happen
  3. Teekar.2023
    Gingerbread May 13, 2020
    Teekar.2023 , via OnePlus 5T , May 13, 2020 :
    Whenever I restart the phone, the override force-dark turns off from the developer settings. The toggle is on but it doesn't work until I turn it off and turn it on again. And after doing that, the phone customization options revert to square, dark mode, blue color, and roboto font.
  4. machine318
    Cupcake May 13, 2020
    machine318 , May 13, 2020 :
    game space doesn't recognize games installed on the work profile and also doesn't have an option to disable the fingerprint sensor while active (this was an option under P)
  5. G1564463744705
    G1564463744705 , May 13, 2020 :
    Hello sir i got that in this beta update mobile oneplus5 get heated more in 15 min when we played pubg mobile before it's not before get heat but now it's too more get heat as not i expect before like this
  6. Kusai_Ghadiyali
    Froyo May 13, 2020
    Kusai_Ghadiyali , via OnePlus 5T , May 13, 2020 :
    You'll have to download the stable version from the OnePlus version for Android P for that
  7. Abhinavkk
    Eclair May 13, 2020
  8. E1545988921100
    E1545988921100 , May 13, 2020 :
    sir my one plus 5t mobile phone update after Android 10 beta 2 some applications not work properly and phone pe Google Pay application are no properly work not registered this device so plz solve this bug
  9. E1545988921100
  10. I1517068557818 likes this.
  11. Udaya_Chendur
    Honeycomb May 13, 2020
  12. dayarampatel
    Froyo May 13, 2020
    dayarampatel , via OnePlus 5 , May 13, 2020 :
    This is beta is supposed to have issue please explain the issue in detail so maybe in next update it's fixed.
  13. dayarampatel
    Froyo May 13, 2020
    It's Closed Beta 3 right now, when its completely cooked it will be made available for us, btw your in such a rush why not try Hydrogen OS it has beta 3.
  14. dosse1985
    dosse1985 , May 13, 2020 :
    I tried looking online to no avail. Does any of you know why Gmail doesn't respect the Do Not Disturb and produces a small vibration to each message with Android 10? Below the screenshot of my settings.
    Thank you in advance
  15. E1545988921100
    UPI apps such as phone pe,Bhim UPI , Google Pay aap not add bank account and not registered again in device phone pe aaps show
    phone pe aap are shee
    Google Pay aap are shee
  16. dayarampatel
    Froyo May 13, 2020
    You will have to download the full zip file of the version you wish to downgrade and manually backup file,
    Then using recovery mode and fully erase everything
    Then adb push the full Ota zip file and it will automatically downgrade to android 9.
    Zohaib Nisar likes this.
  17. djaym7
    djaym7 , via OnePlus 5 , May 13, 2020 :
    Google messages crashes everytime I try to type in a message, cleared data, cache uninstalled and installed and also tried other messaging apps but none of them work except for stock!
    getnimesh likes this.
