211
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. Sid_Ck
    Ice Cream Sandwich May 20, 2020
    Sid_Ck , via OnePlus 5T , May 20, 2020 :
    my wild guess is end of this month if we are lucky, if not next month for sure
  2. G_Deval_Kotadia_CPyn
    Cupcake May 20, 2020
    G_Deval_Kotadia_CPyn , May 20, 2020 :
    thanks a lot for your kind reply...will wait till release stable version.
  3. Altamash Shaikh
  4. Dileep_M_S
  5. christophedcosta
    Eclair May 20, 2020
  6. Altamash Shaikh
    Altamash Shaikh , May 20, 2020 :
    tentative time
  7. christophedcosta
    Eclair May 20, 2020
    christophedcosta , via OnePlus 5 , May 20, 2020 :
    seems they need to iron out all the issues here and go through some more beta rounds before launching a stable release
    bpaterson likes this.
  8. jontalk
    jontalk , May 20, 2020 :
    I'm also curious when the stable version will be released especially since there's been 14 betas for updates to the 7/7T. That's a LOT of beta builds :)
  9. Altamash Shaikh
    May be next month?
  10. Pierre02
    Honeycomb May 20, 2020
    Pierre02 , May 20, 2020 :
    It's already here...
  11. Altamash Shaikh
  12. Josemartin1&
    Josemartin1& , May 20, 2020 :
    The best way to fix this and oneplus gestures is:
    Home screen & keyboard gap (credits fron xda developers)
    - Enable adb debug in developer settings
    - Connect phone to a pc
    - Install ADB from here https://forum.xda-developers.com/showthread.php?t=2588979
    - Run cmd, go to adb directory
    - type adb devices. It should show a message with the name of your device being recongized
    - type adb shell wm overscan 0,0,0,-100
    - If you want to go back to the original gap, type adb shell wm overscan 0,0,0,0
    Voila
    This will remove the android 10 bottom line as well
    Andriod 9 Gestures (credits fron xda developers)
    No root required
    - Download Settings editor from here https://play.google.com/store/apps/details?id=by4a.setedit22
    - Run it, and go to System table
    - Search for "op_gesture_button_side_enabled"
    - Edit value and change it to 0
    - If you want to go back to the original gestures, change value to 1
    Voila
    This two actions will bring back Oxygen 9 feeling again to our phones
    Marek S., Shoryaz, chiragudin and 6 others like this.
  13. Aamir Aman
    Eclair May 20, 2020
  14. Pierre02
    Asking for it every second will not bring it to you in avance
    No. Wipe cache via recovery
    Shobhandana likes this.
  15. Altamash Shaikh
  16. shaanjayu1
  17. Stirlin2001
    Froyo May 20, 2020
    Stirlin2001 , via OnePlus 5T , May 20, 2020 :
    You can just install OB3 direct from Stable Android 9
    Download the OB, save to root of internal storage, reboot to recovery. wipe cache, install, wipe cache, reboot.
    That being said, I suggest doing a backup, wipe and reinstall.
    Read the original post for other guidance.
    erikronao likes this.
  18. bala@9605
    Donut May 20, 2020
    bala@9605 , May 20, 2020 :
    Am using vodafone india network while using data some apps not opening like hdfc netbanking after choose jio all apps working fine ..anybody having this issue
  19. L1589907970229
    L1589907970229 , via OnePlus 5T , May 20, 2020 :
    please add that Wi-Fi sharing over hotspot doesn't work. Wi-Fi simply turns in trying to share via hotspot.
