210
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. sweggitity
    Ice Cream Sandwich May 19, 2020
    sweggitity , May 19, 2020 :
    These bugs are still present, and I have reported them in previous build also. Bugs in OB3.
    1. WiFi switches off in the morning, when you go to sleep for the night.
    2. when the multitasking pane is opened, the glitches for a second and shows the second app instead of the primary from where the multitask is activated.
    3. Bluetooth audio is lower when using an equilizer, I am using Equilizer Pro FX, not sure if it's app problem or Android 10, but on Android 9 the volume was fine.
    4. OnePlus Launcher is not available on the Play Store.
    5. WiFi stability is poor.
    6. Camera bug, when switching from video mode in 1080p 60fps to photo mode, it doesn't switch to back to video mode.
  2. Shidharth Jayakannan
    Gingerbread May 19, 2020
  3. sempi601
    Donut May 19, 2020
    sempi601 , May 19, 2020 :
    Also change the extension from .jar to .zip ;)
    P1588281947085 likes this.
  4. Pigoz
    Cupcake May 19, 2020
  5. sweggitity
    Make sure you have disabled PIN, fingerprint, face lock, pattern or whatever, just make it swipe to unlock. Go to TWRP, clear cache and dalvik then flash the rom, then flash magisk then reboot.
  6. maurocaputo
    Donut May 19, 2020
  7. g_tur92
    Froyo May 19, 2020
    Ravi BINAVAT likes this.
  8. sempi601
    Donut May 19, 2020
    I'm pretty sure that you won't be able to upgrade to stable via OTA. You will have to flash is manually as these betas currently.
    Ravi BINAVAT and Shubham Gujjar like this.
  9. Harry Shank
  10. Sathishsekaran
    Eclair May 19, 2020
  11. Elmar42
  12. sempi601
    Donut May 19, 2020
    Why don't you read the first post?
  13. PrakashRout , via OnePlus 5 Midnight Black , May 19, 2020 :
    System
    Optimized the system icons in UI of call recording, start-up animations, mobile signal, etc.
    What kind of system icons UI optimization is done? anyone found any changes? I couldn't find any changes.
  14. smashers007
    Eclair May 19, 2020
    smashers007 , May 19, 2020 :
    Audio tuner is still greyed out after connecting my Bluetooth earphones.
    Device: OnePlus 5T
  15. smashers007
    Eclair May 19, 2020
    Notifications on messaging apps like Slack are delayed. This happened with the previous Open Beta 2 as well.
    Device: OnePlus 5T
    Some messages appear in the notification but when when you open the app. The messages are missing.. weird.
  16. FusionBomber
    Honeycomb May 19, 2020
    FusionBomber , via OnePlus 5T , May 19, 2020 :
    You recreated the famous quote of Rahul Gandhi: This morning, I got up at night.
  17. sachkharb
    sachkharb , May 19, 2020 :
    why is airtel vowifi disabled in this update? this is not a good thing.. or atleast gives us a reason to do so
  18. J_bara
    Donut May 19, 2020
    J_bara , May 19, 2020 :
    Does optimized charging work for anyone? I see no effect after enabling it. (Afaik, a notification should appear, that my phone will charge to 80% only.)
    #38
    AzadHossain, Nikkhil and Ravi BINAVAT like this.
  19. g_tur92
    Froyo May 19, 2020
    #39
  20. ash_insiider
    #40
