200
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. riozero96
    Eclair May 21, 2020
  2. stefan82mihai
    Cupcake May 21, 2020
  3. B1587298552904
    B1587298552904 , via OnePlus 5 , May 21, 2020 :
    I'm using OBT based on android 9 and I wish to install this via recovery. I backed up the data through OnePlus switch but I can't copy the file anywhere. Can you please tell me if the backup will also be wiped if I install this. thanks!
  4. ninja123456
    Ice Cream Sandwich May 21, 2020
  5. Pierre02
    Honeycomb May 21, 2020
    Pierre02 , May 21, 2020 :
    Copy it to a PC
  6. ninja123456
    ninja123456 , via OnePlus 5 Midnight Black , May 21, 2020 :
    the description in the first page says that oneplus switch cannot backup your data. you need to transfer it to another device
  7. faqir.m.abdullah
    Froyo May 21, 2020
  8. sagarn05
  9. sagarn05
  10. vetoni
    vetoni , via OnePlus 5 , May 21, 2020 :
    after this update
    using messenger youtube opera
    some minor games like brawl stars getting a bit hot not used like previous versions
  11. yel
    yel , via OnePlus 5 , May 21, 2020 :
    yeah it seems so. deleteting the work profile did not help... i'll try it with a bug report... don't want to reset everything... 🙄
  12. mkv13
    Donut May 21, 2020
  13. M1585517150086
    M1585517150086 , May 21, 2020 :
    this open beta is full of bugs.previous version was much better than this one.UI feels choppy.lags as well as stuttering can be found more often.as an example sometimes when i try to go recent apps window it stutters.again when opening settings app it lags and takes more time than before.hope developers will fix this problems with next update.peace.
    Inha1966 likes this.
  14. batmix75
    Eclair May 21, 2020
    batmix75 , May 21, 2020 :
    Hello !
    Thx to the team for the Beta 3 ! That's great [e]1f601[/e]
    I don't have any issue beside some little lags few times..
    I have only one feedback about the multi tasking view. It seems that's stuck to the Android status bar at the top of the screen.
    I attach a screenshot to show you this "UI problem".
    Is this view looks like the same to all of you guys ?
    Regards,
    Mike
    aero2 likes this.
  15. stefan82mihai
  16. stefan82mihai
  17. Murdana
    Gingerbread May 21, 2020
  18. aero2
    aero2 , via OnePlus 5 , May 21, 2020 :
    When I'm on parallel Snapchat I can't go to normal Snapchat by double tap the home button. When I'm elsewhere that double tap works. In beta 2 it was also like that
  19. G_Sanchit_Bhatnagar_dSYB
    Gingerbread May 22, 2020
    G_Sanchit_Bhatnagar_dSYB , via OnePlus 5 , May 22, 2020 :
    you know instead of just saying this vaguely, you could actually help the community by pointing out the bugs which could be fixed when acknowledged. Your comment was no good. it's in beta, it's sure to have bugs, telling them and stuff is what'll make the stable come faster
    aero2 and Marleyfan61 like this.
  20. stefan82mihai
    Cupcake May 22, 2020
    stefan82mihai , May 22, 2020 :
    Guys, my oneplus 5 doesn't open after android 10 update from recovery. It' stays like this form 2 hours! Please help me!
    vivthegod likes this.
