190
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. ninja123456
    Ice Cream Sandwich May 23, 2020
    ninja123456 , via OnePlus 5 Midnight Black , May 23, 2020 :
    there's not much issues with beta 3 so one can guess it as a no.
    3 beta builds were released in 20 days period.in the next 10 days we can expect a stable. anyhow only 37 days left in q2.
    this was put to test in pie and beta 1/2. what's in beta will come to stable. if not now then in the upcoming releases.
    https://forums.oneplus.com/threads/oxygenos-android-10-open-beta-2-for-oneplus-5-5t.1221108/
    hjs2396 likes this.
  2. pranavcool
    Donut May 23, 2020
    rohanjain99 likes this.
  3. Azhar.01
    Froyo May 23, 2020
    Azhar.01 , via OnePlus 5T , May 23, 2020 :
    thanks for your response but for me its not working
    i have enabled wifi calling but call is going through by sim
  4. G1540876452148
    Cupcake May 23, 2020
  5. Ashfiraza
    Ashfiraza , via OnePlus 5T , May 23, 2020 :
    thank u..! any bug in this?it is a beta version right ..!does orginal android 10will come?
  6. jeetpanchall
    jeetpanchall , via OnePlus 5 , May 23, 2020 :
    Does anybody find bluetooth autocorrect improper in OP5 , I found some issues with Bluetooth automatic connection it does not connected as we start bluetooth on device , I have to go manually to settings and connect , it was perfect in android 9 just instantly but not now [e]1f625[/e]
  7. im.ashish
    Honeycomb May 23, 2020
    im.ashish , via OnePlus 5T , May 23, 2020 :
    Here is my Feedback/Review For Android 10 OB 3 For OnePlus 5t
    After using 6 days!
    # Just after Upgrading maybe or may not but you'll face system lag/hanging/freezing issue
    Solution- Power Off The Device » Press Power Button And Volume Down Button simultaneously » Choose Language » Click On Clear Cache And Reboot it.
    # Stranger Bug-
    Just after clicking on fanatic mode from gaming mode, Sim 2 Network ( Airtel) will loose for sometime ( sometimes it remain till i close the fanatic mode). Sim 1 - Jio
    # Automatic Brightness Was Still Not improved, It's much better in Android 9.
    # Heat While Charging
    This is not a bug, but I this is not liked by many -
    Empty Space Below Gboard ( It can be remove from ADB command but I don't have system and this is seriously not good for my typing. it taking a lot of space and looking weird.
    This is Android 10 feature but I came to know that in OnePlus 7 and higher device it was removed. Hope OnePlus remove this on op5t too.
    What i like in OB 1 And OB 3
    In ob1 the recognition speed of fingerprint was awesome, but it was slightly decreased on OB3.
    In ob1 the face gaming was fun but in OB3, sometime it laga/freez.
    In ob1 the charging speed and batter was just unexpected (Got 7.2hrs Of SOT) But it was slightly decreased on Ob3.
    more will update soon after usage.
    G_Emad_Mosa_YIKE likes this.
  8. gohelbhavik
    Donut May 23, 2020
  9. Subbbataicho
  10. shubhrantdey
  11. vksinha
    vksinha , via OnePlus 5 , May 23, 2020 :
    Exactly. VoWiFi is a necessity, not a fancy thing to have.
    To add in your suggestion, even if there is any complication, it should be resolved instead of putting it to back burner.
    Calling is still most important thing for a mobile phone.
  12. Liehjan
    Lollipop May 23, 2020
    Liehjan , May 23, 2020 :
    This is already the 3rd beta, should be quite stable by now... The stable Android 10 will release next month.
    Ashfiraza likes this.
  13. Aditya_Chilka
    Aditya_Chilka , May 23, 2020 :
    great. update to the rescue. one issue is arcore apps are not supporting now. all AR apps were working well before. example just a line.
    paulomodesto likes this.
  14. shub@512
    gauravmalik007 likes this.
  15. Petya_82
    Gingerbread May 23, 2020
  16. Pierre02
    Pierre02 , May 23, 2020 :
    Use EDL flash or flash rollback package
    Petya_82 likes this.
  17. Petya_82
    Petya_82 , via OnePlus 5T , May 23, 2020 :
    Sorry, I didn’t quite understand you, how is it?) I am not an ordinary user. Is there any instruction?
  18. Szelephimba
  19. ninja123456
