210
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. sweggitity
    Ice Cream Sandwich May 25, 2020
    sweggitity , May 25, 2020 :
    Huh, compared to beta 3, your Build is 200513 and beta 3 is 200511, only 2 days difference on builds... i hope the bugs i stated were fixed on the new build
  2. Brijesh Pandit , via OnePlus 5T Midnight Black , May 25, 2020 :
    ohhh! but working smooth also didn't got any bug till now
  3. sweggitity
  4. Some_Random_Username
    Honeycomb May 25, 2020
    Some_Random_Username , May 25, 2020 :
    Hey mate, can you check your PMs please, I have a method to know what is the update file name that was given to you by OTA, it would allow everyone here to update their device.
  5. tazd
    Eclair May 25, 2020
    tazd , via OnePlus 5 , May 25, 2020 :
    Data wipe is a must to avoid bootloop and loss of data.
    beta 3 is pretty stable but if you not open to compromises then i would suggest you to wait, beta is all about bugs so there would be some.
    like for example , i have been facing one where split screen is not working properly with 3rd party launchers which is a huge setback for me.
  6. sweggitity likes this.
  7. ninja123456
  8. OneZ85
    Donut May 25, 2020
  9. Waveform Modifier
    Marshmallow May 25, 2020
    Waveform Modifier , May 25, 2020 :
    All beta related comments, inquires and complaints must be directed to the pinned beta thread only.
    Please remove your thread.
  10. Sandy89
    Cupcake May 25, 2020
    Sandy89 , May 25, 2020 :
    I am on open beta 33, I tried to install the update through oxygen updater but it says it will wipe up all the data, please guide me. 2nd thing is where would I find the root directory where the installed file has to be kept. thanks
  11. Sanjay@1105
    Sanjay@1105 , via OnePlus 5T , May 25, 2020 :
    After updating open beta 3 in oneplus 5T I am facing Time lag around 3 seconds when I open setting option.once I open settings then next time onwards opened fastly. Is there anyone facing this issue like me??
    FredericoMaia likes this.
  12. Sid_Ck
  13. sweggitity
  14. paulomodesto
    Jelly Bean May 25, 2020
    paulomodesto , via OnePlus 5T , May 25, 2020 :
    Yes I'm!
    Sanjay@1105 likes this.
  15. rohanjain99
    Eclair May 25, 2020
    rohanjain99 , May 25, 2020 :
    Brijesh Pandit
    it is stable ! and i was in stable from the beginning​
    Not all users got an stable update on OTA right now ? you may be lucky one [e]1f609[/e]
  16. paulomodesto
    My work just the opposite.
    At night when I'm sleeping it Switches off, than in the morning I wake up the Smartphone and I can see the wifi is disconnected and it instantly connects again, it works just as configured to do.
  17. paulomodesto
    Guess they must be releasing it by stages, as always they have done.
    rohanjain99 likes this.
