197
OxygenOS Android 10 Open Beta 3 for OnePlus 5/5T
  1. K1531490284182
    Cupcake May 26, 2020
  2. Hemant_5T
  3. pratp_singh
    Donut May 26, 2020
  4. sachkharb
    Ice Cream Sandwich May 26, 2020
    paulomodesto and AnkurSri like this.
  5. K1531490284182
    K1531490284182 , May 26, 2020 :
    [e]1f602[/e][e]1f602[/e]
  6. ninja123456
    ninja123456 , via OnePlus 5 Midnight Black , May 26, 2020 :
    maybe they started rolling out stable android 10 and something went wrong or they changed their mind or they felt guilty of rolling out the buggy build our they decided to further delay and make users wait among other things.
    Siddj38 likes this.
  7. DogeAlpha
    Honeycomb May 26, 2020
  8. Pierre02
  9. DogeAlpha
    DogeAlpha , May 26, 2020 :
    We already knew bottom gestures were removed. But they even had the guts to put that in the changelog of the stable version smh
  10. zer0se7en
  11. DogeAlpha
    DogeAlpha , via OnePlus 5T , May 26, 2020 :
    Google said it's mandatory to implement them (I guess it only applies to phones without hardware navigation keys, hence op5 doesn't have them), but they never said you can't modify them (like hiding the bottom bar) and they never said "You can't offer your own gestures in addition to ours" (since Samsung and other OP phones still have their own gestures)
  12. zer0se7en
    zer0se7en , via OnePlus 5T , May 26, 2020 :
    Ofcourse I am talking about a full screen phone. But the feature should always be available on 10 along with the OSs other gestures or nav keys. Maybe original OP gesture was taken away because they are too identical.
    But as far as the usage go with this Google gesture, my hand muscle memory finds it more useful now than the original. The stress from reaching the bottom just to slide up to go back is non existent anymore. So I just embrace it and not complain about it.
  13. DogeAlpha
    I've yet to try the new ones. If you turn on auto rotate and hide the bottom bar while using gestures do you get the rotate icon in the bottom? Or do you need to have that bottom pill bar visible
  14. andreacos92
    Gingerbread May 26, 2020
    andreacos92 , May 26, 2020 :
    +1
    For my usage, they would be almost perfect if they can be triggered only on the bottom half of the sides, so the upper side of edges can still swipe to open lateral hamburger menu, or just to use other thirdy app gestures (that I was using).
    Having the back gestures all way long the sides is a bit too much in my opinion.
  15. zer0se7en
    Unfortunately we have to turn on the pill for the rotation to appear. ☹️
  16. andreacos92
    If you mean "turn OFF auto rotate", so yes you can have that little button in the bottom left angle to rotate screen when you tilt the phone, even with gestures on and auto rotate off.
    EDIT: I have it on OP5, but maybe because I activated new Android10 gestures through adb command
  17. DogeAlpha
    But if you have gestures enabled and you choose to hide the bottom bar, you won't get that rotate icon apparently. you might want to look into that
  18. zer0se7en
    I agree. Those back gestures should be til the half of the screen at the most. But so many members here requested it to be until to almost the top of the screen. Many of those members were newbies on the 7T section. And OnePlus implemented their request.[e]1f621[/e]
  19. NIK3SH
    Froyo May 26, 2020
    bobbyshahi likes this.
  20. S1590486262643
