432
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Max.Mar
    Jelly Bean Jul 8, 2021
    Max.Mar , Jul 8, 2021 :
    Good..plz test all the things and do provide your review of it, so that can help others to know if its good enough to install.
    ANUPCM and D.Sai Suhail Baba like this.
  2. maximus2708
    Gingerbread Jul 8, 2021
  3. rhyd1am
    KitKat Community Expert Jul 8, 2021
    rhyd1am , via OnePlus 6T , Jul 8, 2021 :
    open the file manager app and locate the file you downloaded. Check that the file name ends in .zip. If the file ends in .jar then you'll need to delete the .jar bit from the end of the name.
    Next check that the file is placed in the root directory by locating the file in file manager and long pressing the file>hit the 3 dot menu in the top right corner>click copy>select internal storage and then paste.
    Next go to system>settings> system update>click on the settings cog in the top right corner>local upgrade and choose the file you downloaded.
  4. VJM_21
  5. AnoopChelsa
    Eclair Jul 8, 2021
    AnoopChelsa , Jul 8, 2021 :
    Oxygen os 11 beta version update failed. showing system update installation failed. any solution??
  6. Laurined
    Cupcake Jul 8, 2021
  7. SamiHoufaf
    Cupcake Jul 8, 2021
  8. bigalcy
    bigalcy , via OnePlus 6T , Jul 8, 2021 :
    In previous last betas OnePlus had a way to go from the final beta to the stable version without loosing data do you they will do this again?
  9. Tirth Trivedi
    Donut Jul 8, 2021
    Tirth Trivedi , Jul 8, 2021 :
    Updated from the previous beta version to this, all the data is still there but the phone wont accept the correct password. Tried restarting like 10 times, no luck. Might have to factory reset. Does anyone have a possible solution to this except rebooting/rebooting into safe mode (using a op6 btw).
  10. Sonu14
    Cupcake Jul 8, 2021
  11. ItsRavi25
  12. lilicaull
    Eclair Jul 8, 2021
    lilicaull , via OnePlus 6T , Jul 8, 2021 :
    Updated and I'm still not happy with my life ! So probably A11 wasn't it.
    All jokes aside, so far so good. Still weird when A12 is around the corner, but that's another discussion.
    Keep'em coming !
    Mr. BG likes this.
  13. R1575273532620
    Cupcake Jul 8, 2021
  14. BabaAdamKhan
    Froyo Jul 8, 2021
  15. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jul 8, 2021 :
    I think you're the first who face this issue, hope you have downloaded correct file.
    Try this
    Delete the old file and download again.
    ONEPLUS 6
    https://oxygenos.oneplus.net/OnePlus6Oxygen_22.Y.75_OTA_0750_all_2106301542_1d1d514b855d4f03.zip
    ONEPLUS 6T
    https://oxygenos.oneplus.net/OnePlus6TOxygen_41.Y.75_OTA_0750_all_2106301542_cdf30796f5124365.zip
  16. rhyd1am
    When downloading the file use your browser and it will then download just fine.
    Auristic, Caomhin and Dresa91 like this.
  17. kouzelnik3
    Ice Cream Sandwich Jul 8, 2021
    kouzelnik3 , via OnePlus 6 , Jul 8, 2021 :
    First you need to open those links in browser like Chrome, not in the community app.
    rhyd1am likes this.
  18. Rajeev_ism
    Eclair Jul 8, 2021
    imwasimkhan likes this.
  19. kouzelnik3
    Mine doesn't show anything special even as it seems to be turned on.
