430
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Jul 18, 2021
    Ghazala.Yasmeen , Jul 18, 2021 :
    We have got in touch with you through personal message, request you to check for the same.
  2. Sterben.113
    Froyo Jul 18, 2021
    Sterben.113 , via OnePlus 6T , Jul 18, 2021 :
    When you install the OTA, It is installed in the inactive slot, so don't reboot, go to magisk and install to inactive slot where the OTA currently is. On next reboot when the Android 11 boots up, it is already rooted.
    D.Sai Suhail Baba and Tom886 like this.
  3. Sterben.113
    Froyo Jul 18, 2021
    Should've said this from the start! Now go to feedback and post them to see if any other person is facing this, for me the battery drain will be fixed in some days, everything you mentioned are minor bugs and I'm not facing them atleast.
  4. Ghazala.Yasmeen
    We have responded to your concern via personal conversation, please check for the same and let us know if it's working fine.
  5. kouzelnik3
    Ice Cream Sandwich Jul 18, 2021
    D.Sai Suhail Baba likes this.
  6. GauravaRai
    Honeycomb Jul 18, 2021
  7. JKP6T
    Cupcake Jul 18, 2021
    JKP6T , via OnePlus 6T , Jul 18, 2021 :
    Hey. My OnePlus watch is not longer abel to see a phone call. Its asking to connect the phone. But it s already connectet and all other apps are workinig. Its after last update/hotfix. What to do?
  8. rhyd1am
    KitKat Jul 18, 2021
    rhyd1am , Jul 18, 2021 :
    Check that you have not inadvertently changed the permissions for the watch to have access to the dialer etc.
    Also worth providing feedback https://forums.oneplus.com/feedback
    Although to be honest, I strongly suspect that anyone you speak to from OnePlus will suggest resetting the watch.
    D.Sai Suhail Baba, Auristic and JKP6T like this.
  9. Tom886
    Tom886 , Jul 18, 2021 :
    Yeah, I know this method, just did always the old fashioned way by Fastboot and either TWRP or for now with a patched boot image.
    Interesting part was, when I installed the first Open Beta, the active slot was B, now after the hotfix installation, complete reboot and then to fastboot, the active slot was A.
    First time I had that.
    Cheers
    Tom
  10. JKP6T
    👍 Its tjekt, and have try the other things. Its worked before the hotfix
  11. user_OnePlus6t
  12. Joby Varghese
    Eclair Jul 18, 2021
    Joby Varghese , via OnePlus 6 , Jul 18, 2021 :
    Did you install the hotfix which is released yesterday?
  13. user_OnePlus6t
    user_OnePlus6t , via OnePlus 6T , Jul 18, 2021 :
    Yes I did.
    If I click and wait for a while it does get saved, but the app hangs and doesn't save when I immediately preview a picture or click multiple pictures.
  14. Tom886
    Delete cache and data from Camera, Gallery and Google Photos.
    Cheers
    Tom
    Auristic and user_OnePlus6t like this.
  15. Vaishalivishal
  16. D.Sai Suhail Baba
    Jelly Bean Jul 18, 2021
    D.Sai Suhail Baba , via OnePlus 6T , Jul 18, 2021 :
    Settings -- System -- Reset Options -- Select reset Wifi , mobile and Bluetooth and Done , after that you have to reconnect WiFi and Bluetooth devices again. It may fix issue. Try it.
    Royal_RJ, Auristic and rhyd1am like this.
  17. RajulaRReddy
    Donut Jul 18, 2021
  18. Hakaiishin
    Froyo Jul 18, 2021
    Hakaiishin , via OnePlus 6T , Jul 18, 2021 :
    The issues which were present in the original beta built are still present after the Hotfix update.
    Nothing changed!
    It actually worsened my screen colour calibration.
  19. Myownoneplus6T
    Gingerbread Jul 18, 2021
    RajulaRReddy likes this.
