431
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. KroDoog
    Cupcake Jul 18, 2021
    KroDoog , via OnePlus 6T , Jul 18, 2021 :
    Bug report has been submitted.
    I used the initial beta release, and downloaded the release that was available yesterday, July 17. Both beta builds for Android 11 have caused my Telus Canada mobile data to stop working. Reviewing with a Telus technician, the APN is incorrect. Carrier pushed an update to carrier settings but the phone will not received it.
    Freedom mobile SIM and mobile data work flawlessly, in the same OP6T.
  2. hk_o2
    Honeycomb Jul 18, 2021
    hk_o2 , via OnePlus Community App , Jul 18, 2021 :
    Rename the file for .zip.jar to .zip
  3. ItsRavi25
    Jelly Bean Jul 18, 2021
    Auristic likes this.
  4. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Jul 18, 2021 :
    Check this post..
    Same thread pg 41 .....post #813
    Maybe this will solve your problem.
    Auristic and rhyd1am like this.
  5. VikramMohal
  6. AyazIsayev
    Froyo Jul 18, 2021
    AyazIsayev , via OnePlus 6 , Jul 18, 2021 :
    Thanks for your work!
  7. M1535609789521
    Eclair Jul 18, 2021
    M1535609789521 , via OnePlus 6 , Jul 18, 2021 :
    Great to get this update this early, but still I am facing various issues
    - Watching videos above 480p will lead to frame drop and lags
    - Font size is not very accurate and convenient
    - Call interface is zoomed which is not looking good
    - Observed crash in camera app and some minor crash in other app
    - Loss of internet connection while screen is turned off (Sometimes, Specially with google assistant)
    Rest your efforts are very much appreciated.
  8. Source Unknown
    Donut Jul 18, 2021
    Source Unknown , via OnePlus 6T , Jul 18, 2021 :
    Original Beta:
    - Android Auto doesn't display on car infotainment screen at all.
    - Fingerprint scanner very unreliable, stops working intermittently (constantly says 'moved to fast try again, an error that also occurred on early version of A10)
    - Google app occasionally crashes/force closes
    After hotfix:
    - Android Auto doesn't display on car infotainment screen at all (works on device screen though)
    From my perspective this is a decent start, but these two issues are quite annoying and means I would not recommend anyone to install this as their daily driver.
    DurchEins and Ankit_Rahull like this.
  9. C1542526158633
    Eclair Jul 18, 2021
    alan mosses likes this.
  10. G_Nirav_Chotalia_TloE
    G_Nirav_Chotalia_TloE , Jul 18, 2021 :
    I already updated on OB1, I try to update hotgix through oxygen updater, i successful download but when I want to select local upgrade, I got error like move installation package in to root directory. Already it's in root directory.
    Please help to resolve
  11. NaveCraft5
    Eclair Jul 18, 2021
    JKP6T likes this.
  12. Rishav_Sethia
    Eclair Jul 18, 2021
    DurchEins likes this.
  13. SpartaKurd
    Eclair Jul 18, 2021
    SpartaKurd , Jul 18, 2021 :
    Why are you so aggressive on people here? Is oneplus your own company? Please be kind and gentle. You don't have any rights to behave like this.
  14. Auristic
    Lollipop Jul 18, 2021
  15. Arun_Krr
    Gingerbread Jul 18, 2021
    Arun_Krr , via OnePlus 6 , Jul 18, 2021 :
    Getting a Good battery life overall when compared with android 10 after installing this Android 11 Open Beta 1 in my OnePlus 6. Nd now it's even better after this new Hotfix update. Getting SOT of 7Hrs.
    Ankit_Rahull likes this.
  16. vigneshmiller
    vigneshmiller , via OnePlus 6 , Jul 18, 2021 :
    I love it and it's super stable
    But I have issues with the Camera
    It takes picture and it disappears and WhatsApp camera clicks and won't show pictures
    Hope they fix it soon
  17. kemi666
  18. Sterben.113
    Froyo Jul 19, 2021
    Sterben.113 , via OnePlus 6T , Jul 19, 2021 :
    whenever you install OTA, it gets installed to inactive slot, it always swaps after update, that's why you dont have to reboot while the update is installing. It gets installed and a simple reboot is done. That's why this magisk option is great for this. I used to do it the old fashioned way as well, but after this, this is more simple. If something goes wrong which will not mostly, You still can get the stock img which magisk backs up before patching it or from the payload bin.
    Cheers,
    Sterben.
