429
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. kemi666
    Cupcake Jul 19, 2021
    rirozizo likes this.
  2. rirozizo
    Eclair Jul 19, 2021
    rirozizo , via OnePlus 6T , Jul 19, 2021 :
    Make sure you use the TWRP for your device. Mind is a 6T and I can see yours is a 6.
  3. ItsRavi25
    Jelly Bean Jul 19, 2021
    ItsRavi25 , via OnePlus 6T , Jul 19, 2021 :
    I hope you know what is beta version ? . 😇
    Send your feedback here
    Contact OnePlus support using feedback option OR
    you can submit your idea to Oneplus Developers.
    For Suggestions
    https://www.oneplus.com/communityideas#/
    For Feedback
    Auristic and Caomhin like this.
  4. AbhinavJamwal
    Eclair Jul 19, 2021
    AbhinavJamwal , via OnePlus 6 , Jul 19, 2021 :
    Why is every video playing above 480p on youtube lagging so much. If it is a bug fix it, if not then guide me through a fix!!
    Previous bugs:-
    Quick share in camera app still not working
    Font is somewhat different here and there
    Battery backup seems to be fine after hotfix..
    Alounphras likes this.
  5. Bandarshan
    Donut Jul 19, 2021
  6. Alounphras
    Alounphras , via OnePlus 6 , Jul 19, 2021 :
    Thank you sir
  7. kemi666
    kemi666 , via OnePlus 6 , Jul 19, 2021 :
    Doesn't work unfortunately. When I fastboot boot twrp.img it boots to crashdump mode
  8. Alberto100
    Froyo Jul 19, 2021
    Alberto100 , via OnePlus 6 , Jul 19, 2021 :
    Disable the "vibrant color effect" option found in the display settings. It is a known bug that can currently be worked around in this way.
  9. Ab14801
    Eclair Jul 19, 2021
  10. Auristic
    Lollipop Jul 19, 2021
    Auristic , via OnePlus Community App , Jul 19, 2021 :
    It will.
    Wise choice if you're not that familiar with enduring and solving bugs, backuping and restoring!
    The wait can be long so do that patiently and quietly using your device as usual...
    ItsRavi25, rhyd1am and Caomhin like this.
  11. Pro_Master2233
    Pro_Master2233 , via OnePlus 6T , Jul 19, 2021 :
    I didn't received it yet
  12. Auristic
  13. Tom886
    Honeycomb Jul 19, 2021
    Tom886 , Jul 19, 2021 :
    You maybe should write whether this is for the 6 or 6T
    Depends whether you have a 6 or 6T and how you flashed it.
    Without these information it's impossible to help.
    Cheers
    Tom
    Auristic likes this.
  14. Milan_86
    Donut Jul 20, 2021
    Milan_86 , via OnePlus 6 , Jul 20, 2021 :
    I have just updated to version 11 OB but there is still showing that I have version 10. Does anyone have same situation or just me?
  15. Milan_86
    Donut Jul 20, 2021
  16. Adesh yadav
    Donut Jul 20, 2021
  17. Vikashlb
    Honeycomb Jul 20, 2021
    Adesh yadav likes this.
  18. FaleshC
    KitKat Jul 20, 2021
    Caomhin and LegolasX like this.
  19. FaleshC
    KitKat Jul 20, 2021
    FaleshC , Jul 20, 2021 :
    are you sure you updated to Android 11 OBT and not Android 10 10.3.11?
