412
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Sayan7458
    Froyo Jul 21, 2021
    Sayan7458 , via OnePlus 6 , Jul 21, 2021 :
    Actually I do use it for backing up notes and contacts but I don't like the thing happening.
  2. Harieee
    Donut Jul 21, 2021
  3. rhyd1am
    KitKat Jul 21, 2021
    rhyd1am , Jul 21, 2021 :
    A downgrade, whether stable or beta has always involved a wipe (when the build you're switching to is older than your current).
    To be fair, they do state that fact (and always have done) at the top of the beta threads.
  4. pedrokas28
    Cupcake Jul 21, 2021
    pedrokas28 , via OnePlus 6 , Jul 21, 2021 :
    Where did you get the hotfix update?
  5. rhyd1am
    KitKat Jul 21, 2021
    This is the hotfix update. The links at the start of the thread were replaced with the hotfix.
  6. pedrokas28
    So this is the link to hotfix update?
  7. rhyd1am
    KitKat Jul 21, 2021
    pedrokas28 likes this.
  8. Serdumen
    Serdumen , via OnePlus 6T , Jul 21, 2021 :
    Güncellemeyi yaptım yaklaşık 1 haftadır kullanıyorum, size önerim şudur. Kesinlikle android 11 e geçin mükemmel yapmışlar amk.
  9. Tom886
    Gingerbread Jul 21, 2021
    Tom886 , Jul 21, 2021 :
    Thanks, fully aware of this DSU, my point was, that I get the GSI's (General System Images) offered for Android 12(!) running Android 11(!). This shouldn't happen.
    You can download these from here but correct ones would have been the ones from September 2020.
    Cheers
    Tom
  10. Tom886
    Small hint, you are in the topic of the Android 11 Beta update, Beta updates contain bugs like the one you experience.
    So just go back the last 3 pages of this topic and read whether someone else already reported your problem and whether there is an solution for that. Pretty sure you find it. And no, I won't search for you, that's your job.
    Cheers
    Auristic likes this.
  11. aryegreat
    Cupcake Jul 22, 2021
  12. VikramMohal
    Ice Cream Sandwich Jul 22, 2021
  13. ANUPCM
    Donut Jul 22, 2021
    ANUPCM , via OnePlus 6T , Jul 22, 2021 :
    I am facing the camera issues like portrait mode if I click the photo it has been clicked but when I go and check in the gallery it is not available there so please fix the camera issues in the next build.
  14. 8360664576
    Eclair Jul 22, 2021
    8360664576 , Jul 22, 2021 :
    hi,if i download from here then after installation , is this work properly or not???!!!
  15. 8360664576
    Eclair Jul 22, 2021
  16. iamshiva126
    Eclair Jul 22, 2021
  17. LegolasX
    Jelly Bean Jul 22, 2021
    LegolasX , Jul 22, 2021 :
    Since 12 GSIs available and DSU is a feature introduced in Android 11 and your phone is running Android 11, that's exactly when it should be offered. No? What's the confusion here?
    I have seen people running GSI 12 in a Xiaomi device. It will be a temp rom and probably old version of Android 12 unless they updated the version to the latest one.
    Afaik, you are eligible for gsi if your device is x64 with A/B slot.
    FaleshC likes this.
  18. Vikashlb
    Honeycomb Jul 22, 2021
    Vikashlb , via OnePlus 6T , Jul 22, 2021 :
    you can just install it from Google Play Store 😄
  19. Tom886
    Gingerbread Jul 22, 2021
    Tom886 , Jul 22, 2021 :
    Nope, following the requirements, setup the dynamic system by adb shell, but install fails.
    Cheers
    Tom
  20. LegolasX
    bootloader is unlocked?
