412
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. manasarora98
    Ice Cream Sandwich Jul 22, 2021
    manasarora98 , via OnePlus 6 , Jul 22, 2021 :
    Chat bubbles is not working well, I can see it work with Signal but not with Telegram and Whatsapp.
    On my realme device in realme UI 2.0 beta, it works with all chat apps.
  2. iamshiva126
    Eclair Jul 22, 2021
  3. Vikashlb
    Honeycomb Jul 22, 2021
    Vikashlb , via OnePlus 6T , Jul 22, 2021 :
    you can set google messages as default app instead of OnePlus messaging 😄.
  4. iamshiva126
    Eclair Jul 22, 2021
    iamshiva126 , via OnePlus 6 , Jul 22, 2021 :
    Okay but can you tell me how to remove OnePlus messaging app😂
  5. Vikashlb
    I am not sure but i think you can remove it by using ADB commands.
    RajulaRReddy likes this.
  6. iamshiva126
    Eclair Jul 22, 2021
    I don't want to do any hardwork for my OnePlus 6 it's request to OnePlus commanders to remove OnePlus messaging app and give Google messaging app 🤷🏼‍♂️
  7. Vikashlb
    Nope it wont be removed by ONEPLUS.
    All you can do is use google messages as default app and dont care abt that you have OnePlus messaging in your phone or else keep OnePlus messaging in hidden apps.
  8. rhyd1am
    KitKat Jul 22, 2021
    rhyd1am , Jul 22, 2021 :
    There is no hard work necessary. I've been using Google messages as my default messaging app on every device I have had since Google messages was released.
    Set Google messages as your default app, remove OP messaging app from you homescreen (or hide it as mentioned above), and simply forget about it. 🤷🏼‍♂️
    Auristic and ironass like this.
  9. Vikashlb
    alright found a best solution for you,
    install google messages from play store and set it as default message app and then you will get the option to disable OnePlus messages.
  10. X1621008707213
    Cupcake Jul 22, 2021
    X1621008707213 , Jul 22, 2021 :
    am not able to upgrade its showing the version of your selected package is lower
    currently am on 10.3.12
  11. Vikashlb
    103.12 is latest version so upgrading to OB1 HOTFIX will show as downgrading , wait for OPEN BETA 2.
    ironass likes this.
  12. X1621008707213
    okhieee thankyou
  13. Hafiez_khan , via OnePlus 6T Mirror Black , Jul 22, 2021 :
    After updating my one Plus 6t I'm not able to verify any of my UPI ID. Not able to do any bank transactions on any application. It keeps trying to send an SMS but I don't get any and it's says it's failed. I have enough balance on my card no network issues as in such, even tried changing sim slots, clearing app caches and data, nothing worked. I probably believe it's due to an android update. Any help or assistance with this would be really helpful and appreciated. Thanks
  14. Hafiez_khan , via OnePlus 6T Mirror Black , Jul 22, 2021 :
  15. deep1603
  16. zybster
    zybster , Jul 22, 2021 :
    The file you downloaded ends with .jar ... remove the file ending until you have .zip then it will show up
    Sritejkadiveti likes this.
  17. X1621008707213
    i removed.jar but my problem is that its showing the version of your selected package is lower
  18. Master_TC
    KitKat Jul 22, 2021
    Master_TC , Jul 22, 2021 :
    No you can't update from 10.3.12 to open beta 1 without loss of your data, because 10.3.12 is NEWER then open beta 1.
    --> wait till open beta 2 comes!
    Sritejkadiveti and ironass like this.
  19. Tom886
    Gingerbread Jul 22, 2021
    Tom886 , Jul 22, 2021 :
    Yep, unlocked, rooted, the complete program. Not sure whether feature flags should stay on "Experimental" even after use
    Just open Settings -> App info and Disable the Messages application of OnePlus. Won't show up anymore.
    Cheers
    Tom
  20. Sharma_Rohan
