426
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Master_TC
    KitKat Jul 26, 2021
    Master_TC , Jul 26, 2021 :
    Hocam A11 olan her modelde bu hata maalesef geliyor. Bende dün 2 defa arka arkaya geldi. Bazıları diyor ana kart değişmesi lazım, bazıları da A10 geri dön hata gidiyor diyor. Bende pek bilemedim. Gelecek beta 2 bekliyorum.
  2. D1560784786361
    Cupcake Jul 26, 2021
    D1560784786361 , Jul 26, 2021 :
    I'm using a OP6 which is running on 10.3.12 . The file downloaded is a version which is older than the one mine running on. Please suggest a way to upgrade to Android 11 Beta at this point.
  3. Master_TC
    KitKat Jul 26, 2021
    Roll back to 10.3.11 or wait for beta 2.
    Caomhin likes this.
  4. Derwish
    Eclair Jul 26, 2021
    Derwish , Jul 26, 2021 :
    I'm out of town. I'll go back to the old version when I get home. With the worst msmtool, we go back to 9 and upgrade from there.If there was a motherboard situation, we would be bricked...
  5. Master_TC
    KitKat Jul 26, 2021
    Why MSM tool? Take the official rollback package on the first page. It will install A10.
  6. Derwish
    Eclair Jul 26, 2021
    The msmtool tool will reinstall the modem files...I'm not sure the fallback software will provide this. I'll try anyway...
  7. K1577555224305
    Honeycomb Jul 26, 2021
    K1577555224305 , Jul 26, 2021 :
    Were you able to rescue your 6t
  8. Master_TC
    KitKat Jul 26, 2021
    Yes. After several reboot it's working again. But I don't know how long. At the next Qualcomm crash dump I will roll back to A10 and look...
    K1577555224305 likes this.
  9. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 26, 2021
  10. TORUKMAKTO_12
  11. Master_TC
    KitKat Jul 26, 2021
    Very easy. He was on 103.11 and could update to open beta, because beta is newer.
    You are on 10.3.12 and that is newer then open beta. So you can't update to open beta
    Wait till beta 2 comes out .
    Auristic, rhyd1am and ironass like this.
  12. Zuk.z2
  13. Caomhin
    ItsRavi25 and rhyd1am like this.
  14. Zuk.z2
    Zuk.z2 , via OnePlus 6 , Jul 26, 2021 :
    Hope the next beta comes out soon 🤞. Was excited to install.
    RajulaRReddy likes this.
  15. Auristic
    Lollipop Jul 26, 2021
    Auristic , via OnePlus Community App , Jul 26, 2021 :
    What does excitement have to do with betatesting!?
    Please wake up and be serious for a few seconds: do you really think you've got enough technical knowledge and resilience to go for it?
  16. Tom886
    Gingerbread Jul 26, 2021
    Tom886 , Jul 26, 2021 :
    Damn it, you got me, never paid attention to the version number :D
    Rebboted into recovery, because now you got me curious, but still shows v2.0
    Cheers
    Tom
  17. Tom886
    Gingerbread Jul 27, 2021
    Tom886 , Jul 27, 2021 :
    What's so difficult, download the rollback file to 10.3.11, which is installed the same way as you installed OB1, watch how everything gets deleted, get crazy because you didn't make a backup and then be greeted by a new and freshly installed A10 ;)
    Cheers
    Auristic and rhyd1am like this.
  18. Tom886
    Better stay with that, you want to update to a Beta version which has known bugs.
    Cheers
  19. Tom886
    Awesome, who could ever have the idea that you find there a function like that.
    Great solution.
    Cheers
    Tom
  20. K1549994866803
    Cupcake Jul 27, 2021
