431
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. BeingIncog
    Nougat Jul 9, 2021
  2. Dr.S.NANDAKUMAR
    Cupcake Jul 9, 2021
  3. Shahnavaz patel
    Donut Jul 9, 2021
    D.Sai Suhail Baba likes this.
  4. BeingIncog
    Nougat Jul 9, 2021
    BeingIncog , Jul 9, 2021 :
    It works for everyone, just need to be smart enough and check where are you missing out on details...
    D.Sai Suhail Baba and Ronesso17 like this.
  5. AdityaMagdum108
    Honeycomb Jul 9, 2021
    AdityaMagdum108 , via OnePlus 7 Pro , Jul 9, 2021 :
    What I meant was that is the beta programme still on for Oxygen OS 12 for 7 series?
  6. BeingIncog
    Nougat Jul 9, 2021
    Maybe in future. How can user's know?
  7. Wesllyn
    Cupcake Jul 9, 2021
  8. Vikashlb
  9. kammino11
    Cupcake Jul 9, 2021
    Ronesso17 likes this.
  10. Ronesso17
    Kammino likes this.
  11. Ronesso17
    Ronesso17 , via OnePlus 6T , Jul 9, 2021 :
    Hey guys, so facing a issue here, anytime I open the camera app, or any thrid party camera app like GCAM, the device becomes really slow, and then stops responding. Anyone knows any fix for this?
    R1580286940659 likes this.
  12. H.ELK
  13. sikoo1996
    Cupcake Jul 9, 2021
    sikoo1996 , via OnePlus 6 , Jul 9, 2021 :
    Those who are facing issues with AOD/Ambient display on op6
    1 - uninstall wallpaper resources app
    2 - update Canvas from playstore
    3 - change wallpaper from canvas, this will trigger Ambient display .
    4 - enjoyy
  14. Kvpai
    Cupcake Jul 9, 2021
    Kvpai , via OnePlus 6 , Jul 9, 2021 :
    I tried this beta, no bugs found yet_ except for a glitching animation in the settings.
    Everything else works perfectly
  15. R1580286940659
    Cupcake Jul 9, 2021
    R1580286940659 , via OnePlus 6T , Jul 9, 2021 :
    Noticed a bug so far, search for a contact from caller app and as soon as you click on the name, it redirects you to the caller app. Can't make call. You need to manually search it.
  16. Raghav Shankar
    Eclair Jul 9, 2021
  17. Anmol 45
    Anmol 45 , via OnePlus 6 , Jul 9, 2021 :
    If your AOD/ Ambient display is not working, try this:
    1. Go to settings > Apps and notifications > Show system apps > search for "OnePlus Wallpaper" > uninstall updates/ clear data.
    2. Update "Canvas" from the Play Store.
    3. Set wallpaper using canvas.
    That's it. Now you aod will most probably work.
  18. Anmol 45
    Try this ☝️
  19. VJM_21
    Gingerbread Jul 9, 2021
