426
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Aslamayaaz
    Cupcake Jul 30, 2021
  2. D.Sai Suhail Baba
    Jelly Bean Jul 30, 2021
  3. albibros
    Eclair Jul 30, 2021
  4. Loft85
    Loft85 , via OnePlus 6T , Jul 30, 2021 :
    When I try to do a local update it says it cannot install because the version is older than the one currently running. I'm on the latest stable version.?
  5. Loft85
  6. Psbadola
    D.Sai Suhail Baba likes this.
  7. D.Sai Suhail Baba
    D.Sai Suhail Baba , Jul 30, 2021 :
    https://www.xda-developers.com/oxygenos-open-beta-2-android-11-oneplus-6-6t/
    Download OB 2 Full ZIP file from above link based on your device and do local upgrade it will work.
    fOx621 and Loft85 like this.
  8. fOx621
    fOx621 , via OnePlus 6 , Jul 30, 2021 :
    Cant Update my stable build to the beta as i think few days earlier i updated with security update and now it says the Beta build is lower than my current build so can't update, any id3a how to get the beta build???
  9. Master_TC
    KitKat Jul 30, 2021
    D.Sai Suhail Baba and fOx621 like this.
  10. fOx621
  11. Kartik310
  12. Auristic
    Lollipop Jul 30, 2021
    rhyd1am likes this.
  13. Kartik310
    Kartik310 , via OnePlus 6T , Jul 30, 2021 :
    Yes but still i could not.
  14. Kartik310
  15. Master_TC
    KitKat Jul 30, 2021
    Auristic likes this.
  16. Kartik310
  17. Master_TC
    KitKat Jul 30, 2021
    Master_TC , Jul 30, 2021 :
    You have downloaded something wrong. What is the full name of your file you want to install and how is the size?
  18. D.Sai Suhail Baba
    You have download wrong file , its build number is different from OnePlus 6T OB 2 build number
    said:
    This is current build number of OB 2 for 6T :
    OnePlus6TOxygen_41.Y77_OTA_0770_all_2107231448_c28e77173a8.zip
  19. D.Sai Suhail Baba
    Kartik310 and Auristic like this.
  20. Sunit_Gupta
    Donut Jul 30, 2021
    Sunit_Gupta , Jul 30, 2021 :
    Hi,
    After updating to A11 beta 2, battery is draining really fast. I am wondering if someone else is also facing the same issue and if yes, then any solution for it.
    Regards
