429
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. ajudi46
    Donut Jul 10, 2021
  2. anaggh
    Donut Jul 10, 2021
    anaggh , Jul 10, 2021 :
    Hi, OnePlus 6 user here. Anyone facing Google Account Sync problems on Android 11 Open Beta?
    I have to manually open the apps (Docs/Sheets in this case) which did not sync and refresh/resync from there for some google apps.
  3. Priyanshu Sharma
    Jelly Bean Jul 10, 2021
  4. firewalker9
    Cupcake Jul 10, 2021
    firewalker9 , Jul 10, 2021 :
    Issue: Alert Slider
    My alert slider isn't working. Phone ring is on mute and I have no chance to activate it. Someone has the same and/or this problem solved?
  5. A1625941733545
    A1625941733545 , Jul 10, 2021 :
    The Android 11 update for the OnePlus 6 seems like a good one. But there is stuttering and frame rate drop when watching YouTube videos. I had a good charge and was not using the battery saver mode. No other apps were running in the background.
    This happens when I play a 720p60fps / 1080p60fps video. I watched the gameplay and noticed a steady drop in frame rate. It seemed to be 20 frames per second. It's worth noting that there are no such problems at 480p and below.
    This really needs to be fixed. If this is a way to reduce battery drain, it doesn't help.
    OnePlus, please fix this before the next update and we'll need it soon. Please fix the bug and update as soon as possible.
  6. Manosri007
    Donut Jul 10, 2021
  7. Max.Mar
    Max.Mar , Jul 10, 2021 :
    Okay..lets wait for it.
  8. U1551898310567
  9. Auristic
    Lollipop Jul 10, 2021
    Auristic , via OnePlus Community App , Jul 10, 2021 :
    Since you consider yourself that good at marketing what you recommend is to abandon new devices that bring money and concentrate upon old devices that bring none and cost a lot: you should work at OnePlus as your idea is great!!!
    ItsRavi25 likes this.
  10. Auristic
  11. Auristic
  12. Auristic
  13. rationale
    Froyo Jul 10, 2021
    rationale , Jul 10, 2021 :
    1. Is phone recording there? Anyone tested it yet?
    2. Does Instagram finally work? I mean shows previews of pictures when trying to upload them? It's a bug which is driving me insane.
    nikhilradadiya likes this.
  14. A1625941733545
    [QUOTE = "Auristic, сообщение: 23427418, участник: 19943"] Прочтите в следующий раз перед публикацией, это помешало бы вам опубликовать квест, ответ на который был дан несколько раз! [/ ЦИТИРОВАТЬ]
    К сожалению, я так и не понял в чем моя проблема. Хотелось бы вернуть нормальное воспроизведение видео при высоком качестве
  15. Auristic
  16. DosenHatti
    Donut Jul 10, 2021
    DosenHatti , via OnePlus 6T , Jul 10, 2021 :
    If your phone starts crashing after some time and starts new again and again , that might be Google Fit. Try to delete the app and you are done. Since I deleted Google Fit my phone runs like a charm. OP. 6T
  17. A1625941733545
    [QUOTE = "Auristic, post: 23427566, member: 19943"] Английский или нет ответа! [/ QUOTE]
    Unfortunately, I still do not understand what my problem is. I would like to return normal video playback at high quality
  18. G_Ross_Wheatley_EGFr
    G_Ross_Wheatley_EGFr , Jul 10, 2021 :
    Has anyone had any issues with casting since upgrading? I can't cast from within apps to Chromecast devices both video and audio. This is to Google Mini and Nest Hubs. Trying to connect to the devices in Google Home app fails? I've tried resetting WiFi to no avail.
  19. SpartaKurd
    Eclair Jul 10, 2021
    SpartaKurd , Jul 10, 2021 :
    I'm experiencing some issues;
    1- When I try to install custom recovery, I get "Qualcomm CrasbDump Mode" screen.
    2- Proximity sensor doesn't work.
    3- Auto brightness doesn't work.
    4- vibration doesn't work.
  20. ironass
    ironass , Jul 10, 2021 :
    No
    S1552331707291 likes this.
