432
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Ankit_Rahull
    Eclair Jul 11, 2021
  2. k.mukeshkumar
    Cupcake Jul 11, 2021
  3. aadnan181
    Donut Jul 11, 2021
    aadnan181 , via OnePlus 6T , Jul 11, 2021 :
    said:
    I have it enabled. But not getting any bubble options in individual app settings!
    Edit: Okay my bad. i was checking messenger only. And it says it doesn't support bubble feature. But WhatsApp does.
    Edit 2: Had to reinstall messenger in order to bring bubble feature!
    D.Sai Suhail Baba and Ankitk12 like this.
  4. Ankit_Rahull
    Eclair Jul 11, 2021
    Ankit_Rahull , via OnePlus 6T , Jul 11, 2021 :
    I have charged my device fully but battery status not getting reset..
    Any idea what do i do for this ?? Rebooting the device already tried but its not useful 😕😕
    D.Sai Suhail Baba likes this.
  5. Ankit_Rahull
    Eclair Jul 11, 2021
    Hey buddy i have tried with whatsapp by enabling individually that bubbles feature.. but its not working with any of other apps too
  6. GauravaRai
    Honeycomb Jul 11, 2021
    GauravaRai , via OnePlus 6 , Jul 11, 2021 :
    Does anyone using multi user on android 11 beta1 oneplus 6?
    I'm facing a bug when using multiple users. When I move to one user to another user it doesn't lead me to launcher homepage instead after unlocking user lockscreen it directly opens letest running app and I have to swipe navigation bar to come to launcher homepage.
  7. aadnan181
    Donut Jul 11, 2021
    Try reinstalling the apps.
  8. nolandc
    Eclair Jul 11, 2021
    nolandc , Jul 11, 2021 :
    Open Alpha you mean... No thanks, Ill deal with the bugs when I absolutely have to... Op = bug infestation.
    Ronesso17 likes this.
  9. Ahmedraju
    Eclair Jul 11, 2021
    Ahmedraju , via OnePlus 6 , Jul 11, 2021 :
    The Gmail has an issue.It doesnt shows or pop up notification When mail has been received. Manually open the gmail app and then it shows that mail has alrdy Arrived. And,another bug is Related to using Gcam.Can't shoot Selfie or Anything.Sometimes picture Can be clicked but after as early as open it,It seems to be Vanished.Oneplus Fix this issue.
  10. Anand5266
  11. devesh_702
    devesh_702 , via OnePlus 6T , Jul 11, 2021 :
    Oxygen 12 ???? When it will come to one plus 6t device
    It is mentioned in many google blogs
    Plz specify it officially if ur giving or not giving update
  12. D.Sai Suhail Baba
    Jelly Bean Jul 11, 2021
    D.Sai Suhail Baba , Jul 11, 2021 :
    Oxygen OS 11 will be the last Android Software Update for 6/6T , all those information about OOS 12 on google blogs are for popularity gain and info is fake.
    devesh_702, Ronesso17, amanps and 3 others like this.
  13. Max.Mar
    Max.Mar , Jul 11, 2021 :
    Both your issues are not related to the ROM in any which way. 1. Email notifications are receiving normally, check under battery if you have Optimised it.
    2. My Gcam works perfectly. Which version you have installed? Any if that particular version or Gcam as a whole is not working perfectly than its GCAM issue and not ROM's fault.
    Understood?
  14. Max.Mar
    Why do you want to unlock the bootloader for the stock ROM? If you want a custom ROM than its a different talk. Even if you want to unlock the bootloader than you would be flashing a custom recovery..than you can flash any ROM with it be it stable or Beta but none of which will come as a OTA update for you.
  15. yagyan
    yagyan , via OnePlus 6 , Jul 11, 2021 :
    I want to see if I maintain the widevine L1 after unlocking the bootloader in open beta. In Oneplus 7 it maintained the L1 after getting open beta foe Android 11. But it's my daily driver so can't just install it.. So I was asking for it
  16. rhyd1am
    KitKat Community Expert Jul 11, 2021
    rhyd1am , Jul 11, 2021 :
    Really??? You're demanding that OnePlus fox an issue for an app (modded Gcam) that they have zero responsibility for?
    If the Gcam mod that you're using is no longer working, then find another version that does work. Don't expect OnePlus (or anyone else) to solve a problem with an unofficial app that you've side loaded to your device 🤷🏼‍♂️
    D.Sai Suhail Baba and Auristic like this.
  17. DeadlySin2022
    DeadlySin2022 , via OnePlus 6 , Jul 11, 2021 :
    I have downloaded the android 10 latest zip from oneplus site . Can i rollback with it or do i need to download the rollback file given here. Can anyone help?
  18. Kerngehirn3
    Kerngehirn3 , via OnePlus 6 , Jul 11, 2021 :
    1. Battery icon in quick settings redirects to battery saver instead of battery settings.
    2. Cannot return to nova home screen when pressing home. Need to press a second time. First time brings me to oneplus launcher.
    Already submitted feedback.
    Is it only me or also someone else with this issue?
  19. DeadlySin2022
  20. rhyd1am
    Due to the fact that this beta build is newer than the latest stable build, you won't be able to simply install the latest Android 10. You will have to use the rollback file for your device from the top of this thread.
