414
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. rirozizo
    Donut Jul 12, 2021
    rirozizo , via OnePlus 6T , Jul 12, 2021 :
    Hello,
    Just confirming the GMail app bug where I don't receive any notifications from it unless I open the app itself.
    I tried clearing its data and reinstalling it and it still behaves the same.
  2. Derwish
    Eclair Jul 12, 2021
    Derwish , Jul 12, 2021 :
    I did a clean flash install.
    After 1 day of great and trouble-free use, I came across Qualcomm Crash Dump. I pressed the volume up-down and power button and turned it off. Then I pressed the power button and it turned on normally. For your information...
  3. ARHS2710
    Donut Jul 12, 2021
    ARHS2710 , via OnePlus 6 , Jul 12, 2021 :
    Same issue with me.
  4. I1589714429435
    Donut Jul 12, 2021
  5. Sayan7458
    Froyo Jul 12, 2021
  6. Girdhar Agrawal
    Gingerbread Jul 12, 2021
  7. D.Sai Suhail Baba
    Jelly Bean Jul 12, 2021
    D.Sai Suhail Baba , Jul 12, 2021 :
    Go to settings/storage/music & audio/audio files
    OR
    Android/Data/com.oneplus.communication.data/files/Record/PhoneRecord
    Caomhin, Auristic and Royal_RJ like this.
  8. Max.Mar
    Max.Mar , Jul 12, 2021 :
    None these issues are there..did you clean flashed??
    Auristic likes this.
  9. Girdhar Agrawal
    Girdhar Agrawal , via OnePlus 6 , Jul 12, 2021 :
    In android there is no data
    And in storage only my songs and audio files
    Recording file not available
    Its shows in call log but path is not shown
  10. Girdhar Agrawal
  11. Girdhar Agrawal
  12. Vikashlb
    Honeycomb Jul 12, 2021
    Vikashlb , via OnePlus 6T , Jul 12, 2021 :
    You can access your call recordings in Phone app->Settings->call recording->view all recordings
  13. Filip Randjak
    Froyo Jul 12, 2021
    Filip Randjak , via OnePlus 6 , Jul 12, 2021 :
    Hey, can you guys please recommend your display calibration settings? I am desperate since I can't get the proper calibration myself, looking for some suggestions. Many thanks 🤙
  14. Girdhar Agrawal
    Thanks
    That I know but I am asking the path where it is saved , if I have to transfer to laptop than it is in which folder ?
  15. Max.Mar
    Cud you plz tell me how did you do it..procedure exactly.
  16. Filip Randjak
    Froyo Jul 12, 2021
  17. Girdhar Agrawal
  18. Filip Randjak
    Froyo Jul 12, 2021
  19. Girdhar Agrawal
  20. iammrkt
    iammrkt , via OnePlus 6 , Jul 12, 2021 :
    Loving this beta build. AOD is working like a charm. Ni negative pact felt whatsoever. Good job oneplus. Please go with the AOD feature in stable update too.
