431
OxygenOS Android 11 Open Beta 1 for OnePlus 6/6T
  1. Saptakc
    Froyo Jul 13, 2021
    Saptakc , via OnePlus 6T , Jul 13, 2021 :
    I do many times..the process is Same like stable android 10 to 9??yah,when I want I do complete backup n do what mentioned..n download the file above.
    D.Sai Suhail Baba and rhyd1am like this.
  2. rhyd1am
    KitKat Community Expert Jul 13, 2021
    rhyd1am , Jul 13, 2021 :
    Photos - Google photos
    Contacts - Google backup
    Device data - Google backup
    Messaging apps - Almost every one has a backup option
    Honestly in this day and age, the need to connect to a computer to backup your device is pretty much zero 🙂
  3. rhyd1am
    Yes the same as any other rollback 👍
  4. INSTINCT_YT
    Cupcake Jul 13, 2021
    INSTINCT_YT , via OnePlus 6 , Jul 13, 2021 :
    Not not about photo contact
    It's about my documents and all documents file size 45GB
    D.Sai Suhail Baba likes this.
  5. Saptakc
    Froyo Jul 13, 2021
    Thanks for chats..n given some information.. wishing you a very good night..cya😃👍
  6. Nope.
    Gingerbread Jul 13, 2021
    Nope. , via OnePlus 6T , Jul 13, 2021 :
    Anyone trying to rollback or facing rollback issues can use MSM download tool v2 to go back to OOS 9. Then update to 11. I use it as a fresh installer for any build, custom or official or beta.
  7. rhyd1am
    Yes but surely if those documents were really as important as you say, you would have them backed up somewhere anyway? Especially before entering into using a beta build.
    I make absolutely sure that anything important is always backed up online (I make sure I have multiple backups personally).
  8. rhyd1am
    No problem, have a great night yourself 😁
  9. Auristic
    Lollipop Jul 13, 2021
    Auristic , via OnePlus Community App , Jul 13, 2021 :
    I guess your car also used to run fast before having an engine failure...
    Believe me the space around your slider's button needs a cleanup: there's dust and/or dirt inside...
  10. T1558033066173
  11. Zephyr99
    Froyo Jul 13, 2021
    Zephyr99 , via OnePlus 6 , Jul 13, 2021 :
    Just wanted to say.. this is a great update, i was running the last beta since last year, it was full of bugs... I'm so happy. Little to no bugs at all and a bit battery drain issue which i will happily trade it with the bugs it had before
  12. H1626095232942
  13. Master_TC
    KitKat Jul 13, 2021
    Master_TC , Jul 13, 2021 :
    It will not come, because you have to download and install it manually. But links were removed temporarily, based on users feedback.
    So wait till beta 2 comes.
  14. Iced99
    Iced99 , via OnePlus 6T , Jul 13, 2021 :
    I've run into two issues:
    1. Display P3 does not work, selecting it turns the screen into AMOLED Wide Gamut and it's extremely saturated
    2. I can't play YouTube videos at 1080p without massive stutter and lag in the videos. 720p works but every once in a while there's a slight stutter.
    otherwise besides some transitions looking odd and jittery I've been enjoying my time here
  15. Max.Mar
    Jelly Bean Jul 13, 2021
    Max.Mar , Jul 13, 2021 :
    1. Yes, colour saturation is way off
    2. Turn off Vibrant color effect mode under display
  16. Ankit_Rahull
    Eclair Jul 13, 2021
    Sayan7458 likes this.
  17. julianocas
    julianocas , Jul 13, 2021 :
    On OP6 here and no issue whatsoever.
    The only problem I'm facing is the impossibility to disable Google Assistant. Even changing to "None" the "slide up" still works. I was able to disable inside my Google Account, but the "slide up" still is still enable.
    Also I can't find the notification icon control to disable the visibility of some icons, like NFC and Alarm.
  18. Tom886
    Honeycomb Jul 14, 2021
    Tom886 , Jul 14, 2021 :
    Not for this camera version, v3.14.24 seems to be a complete new branch, so there are no 3 dots available. Previous version I had installed under A10 was 3.0.116
    Cheers
    Tom
    D.Sai Suhail Baba and Max.Mar like this.
  19. Tee_Eee_Bee
    Ice Cream Sandwich Jul 14, 2021
    Tee_Eee_Bee , Jul 14, 2021 :
    Try searching for "Default digital assistant app" in Settings and set the assistant to none and see if that helps.
    Also, search for "Icon Manager" in Settings to enable/disable status bar icons.
