120
OxygenOS Android 11 Open Beta 2 for OnePlus 6/6T
  1. deepak_lko
    Gingerbread Jul 30, 2021
  2. zhenglong
    Cupcake Jul 30, 2021
    zhenglong , via OnePlus 6T , Jul 30, 2021 :
    Chrome browsing isn't smooth on beta 1 but game like genshin impact not as lag, on beta 2 chrome browsing is smooth but game like genshin impact get more lag.
  3. Master_TC
    KitKat Jul 30, 2021
    Master_TC , Jul 30, 2021 :
    Strange... I think the last option is factory reset.
  4. Master_TC
    KitKat Jul 30, 2021
    I think this optimization was a little bit to strong for games:
    Changelog
    • System
      • Optimized the overheating control management of third-party apps
    Caomhin and Auristic like this.
  5. kouzelnik3
    Ice Cream Sandwich Jul 30, 2021
    kouzelnik3 , Jul 30, 2021 :
    Have you tried clean flashing?
  6. divesh rajpurohit
    Eclair Jul 30, 2021
  7. kouzelnik3
    kouzelnik3 , via OnePlus 6 , Jul 30, 2021 :
    Ok, then if you upgraded from stable 10, it is your kind of problem, because clean flash is recommended after major update.
  8. Balry
  9. ItsRavi25
    Jelly Bean Jul 30, 2021
    ItsRavi25 , via OnePlus 6T , Jul 30, 2021 :
    Dirty update or clean installation ?? ...
  10. Tirth Trivedi
    Donut Jul 30, 2021
    Tirth Trivedi , via OnePlus 6 , Jul 30, 2021 :
    For People with colour calibration issues (yellowish tint)
    I tried the cache wipe from recovery, seemed to fix it for a couple of hours, then it came back. Then I went into display>calibration and set it to Amoled wide gamut. Calibration issues haven't shown up since, colours are back to normal.
    This was on a base op6.
  11. tangurocks
    tangurocks , via OnePlus 6T , Jul 30, 2021 :
    Hi...Have u install the 11,how it's works suggest me,me too have 10.3.12!!!
  12. Moulieswaran.E
    Moulieswaran.E , via OnePlus 6 , Jul 30, 2021 :
    Settings->Display->Advanced->Screen Calibration->Advanced->Amoled Wide Gamut
    After changing this you cannot see the yellowish in OnePlus 6
  13. Moulieswaran.E
  14. F1540295725509
    F1540295725509 , Jul 30, 2021 :
    Hi , I'm using one plus 6 and my oxygen OS version is 10.3.12
    I tried installing the android 11 beta version and it shows that my current package is upgraded and it will not allow degrading. but I'm still on android 10 version. what to do now ?
  15. borotrb1
    borotrb1 , via OnePlus 6T , Jul 30, 2021 :
    nope still not working
  16. A1560734135095
    Eclair Jul 30, 2021
    A1560734135095 , via OnePlus 6T , Jul 30, 2021 :
    Always on display not working in this update... For 6t
  17. D.Sai Suhail Baba
    D.Sai Suhail Baba , Jul 30, 2021 :
    https://www.xda-developers.com/oxygenos-open-beta-2-android-11-oneplus-6-6t/
    Download full zip file from above link based on your device and try to upgrade , it will work
    Auristic, Royal_RJ and Caomhin like this.
  18. D.Sai Suhail Baba
    AOD not working :
    Go to settings > Apps and notifications > Show system apps > search for "OnePlus Wallpaper" > uninstall updates/ clear data.
    Update "Canvas" from the Play Store.
    Change wallpaper from canvas, this will trigger Ambient display.
    This method will help you to fix AOD issue.
    Thanks to @ItsRavi25
  19. 8360664576
    Eclair Jul 30, 2021
    8360664576 , via OnePlus 6T , Jul 30, 2021 :
    Hi I m 11 Android version of beta download and ya work it properly 😀.but I m this update from oxygen updater by using the advance mode = anable .....is this workful or harmful for my device or not ??? Any update of beta version download from the oxygen updater is this write or safe for device or not????
    See this images of my one plus 6t device and tell that's write or wrong with beta version....
