120
OxygenOS Android 11 Open Beta 2 for OnePlus 6/6T
  1. ItsRavi25
    Jelly Bean Jul 31, 2021
    ItsRavi25 , via OnePlus 6T , Jul 31, 2021 :
    If you're on 10.3.12 then download OPEN BETA 2 ...
    For 10.3.11 => Open beta 1.
    Auristic and D.Sai Suhail Baba like this.
  2. D.Sai Suhail Baba
    D.Sai Suhail Baba , Jul 31, 2021 :
    Just wait for Stable Update. It's better option if you're not a beta user and you may receive by mid - August or August ending.
    Royal_RJ and Auristic like this.
  3. divesh rajpurohit
    Eclair Jul 31, 2021
  4. prkoparkar
    Froyo Jul 31, 2021
    prkoparkar , via OnePlus 6 , Jul 31, 2021 :
    Heppend with me in OB1. Rebooting phone solved the issue. Hope it will help.
  5. JainHimanshu
    Cupcake Jul 31, 2021
    JainHimanshu , via OnePlus 6T , Jul 31, 2021 :
    Disable oneplus solved for me
    Thanks 🙂 for response
  6. Akshayv322
  7. D.Sai Suhail Baba
  8. G_Rutul_Sam_LjfD
  9. Jignesh7190
  10. Ricaurte Alvarado
  11. HardikVagal
    Eclair Jul 31, 2021
    HardikVagal , via OnePlus 6 , Jul 31, 2021 :
    Mobile data always on active does not work.
    If wifi has no connectivity and mobile data is turned on we cant use internet need to turn-off wifi.
  12. Q1627418224069
    Augustine Moses G likes this.
  13. Max.Mar
    Max.Mar , Jul 31, 2021 :
    That's because you didn't flashed it correctly. This is one of the best update from Oneplus..super smooth and almost no bugs. Even the battery life is way better than A10.
    I would suggest you to flash it again and do Factory reset afterwards. That will solve your 99% problems.
  14. C1624788922607
    Gingerbread Jul 31, 2021
  15. rafid069
    Donut Jul 31, 2021
  16. A I M
    Froyo Jul 31, 2021
    A I M , Jul 31, 2021 :
    NFC don't know but same thing happens with Gmail notifications starts working after restart but after sometime during day stops & have to manually open Gmail app & there are many unread emails
    Problem solved after factory reset from recovery mode
  17. popxunga
    Eclair Jul 31, 2021
    popxunga , via OnePlus 6T , Jul 31, 2021 :
    Hi ...
    My 6T seems to be working fine with 5Ghz WiFi networks with beta 2.
    The Gmail notifications issue was gone after a few days while still using beta 1 and is still working ok after beta 2.
    Camera error is gone as well.
    I didn't notice any lagging with beta 1 or beta 2 ... but I don't use the phone for gaming.
    The battery usage was worst on beta 1 when compared with 10.3.11. It's a bit early to say with beta 2 but it's looks much better when compared with beta 1 or 10.3.11..
    Thanks OnePlus Support Team.
    D.Sai Suhail Baba likes this.
  18. Augustine Moses G likes this.
  19. Adil,Sidiqi003
  20. Zarc
    Donut Jul 31, 2021
    Zarc , via OnePlus 6T , Jul 31, 2021 :
    I faced the screen recording issue. When i recorded the movie in the browser, the video was freezed and it was unable to see any scene changes. This also happened in the ob1, while on 10.3.12, recording with internal audio would make the audio ran faster and chuppy @@
