120
OxygenOS Android 11 Open Beta 2 for OnePlus 6/6T
  1. Master_TC
    KitKat Jul 31, 2021
    Master_TC , Jul 31, 2021 :
    Like on A10. It has not changed. Same setting.
    Auristic likes this.
  2. Jballer25
    Cupcake Jul 31, 2021
    Jballer25 , Jul 31, 2021 :
    I downloaded the beta package, and moved it to the root directory, but it doesn't show up in my system updates even under local upgrade. Anyone know how to get it to work?
  3. adi1001
    Honeycomb Jul 31, 2021
    adi1001 , via OnePlus 6T , Jul 31, 2021 :
    Make sure that file name ends with .zip ....if it ends with .jar then rename it and remove .jar from it.
  4. AdoNemeth
  5. Jballer25
    It worked! Thanks
    adi1001 likes this.
  6. Master_TC
    KitKat Jul 31, 2021
    Strange. I have it there.
    Do you get it if you change the language to English and reboot phone?
    If no perhaps you should make a factory reset.
  7. AdoNemeth
    AdoNemeth , via OnePlus 6T , Jul 31, 2021 :
    After change language, it working, thanks man.
  8. ig_shxvm
    ig_shxvm , via OnePlus 6T , Jul 31, 2021 :
    I am getting 16-35 fps i played a game n recorded the monitor data the fps was fluctuating between 16-35. The games are not even loading fast as compare to before. If someone get solution pls comment 🙂
    iPoseidon111 and Suraj1378 like this.
  9. Z1612812270490
    Donut Jul 31, 2021
  10. ig_shxvm
    Same i am facing issue to
    pavan.kumar.p and Suraj1378 like this.
  11. GauravaRai
    GauravaRai , via OnePlus 6 , Jul 31, 2021 :
    I request @OnePlus or whoever is the moderator or admin of this forum to recognise the PUBG/BGMI lag and FPS drops and put an advisory in opening thread that "if you are gamer or pubg/bgmi player, don't install open beta 2 as breaks game playability"
    I see almost 10-20% post regarding pubg/game lag. Users are getting frustrated after installing b2. Responsible persons here should care about it.
    Suraj1378 likes this.
  12. FrostyFox
    Froyo Jul 31, 2021
    FrostyFox , via OnePlus 6 , Jul 31, 2021 :
    Maybe that's why these builds are called 'beta' and not 'stable'?
    Suraj1378 and rhyd1am like this.
  13. Master_TC
    KitKat Jul 31, 2021
    Please give your feedback through https://forums.oneplus.com/feedback
    Auristic and rhyd1am like this.
  14. gpatrick7
  15. FrostyFox
    Froyo Jul 31, 2021
    Try clearing cache and app data for gmail. I noticed this during beta 1 but a reset after moving on to beta 2 fixed it for me.
  16. gpatrick7
    FrostyFox likes this.
  17. rhyd1am
    KitKat Jul 31, 2021
    rhyd1am , Jul 31, 2021 :
    That's the risk you take (and agree to) when you willingly choose to use beta builds.
    There is already a perfectly adequate disclaimer at the top of every betas thread
    "Note:
    Please keep in mind that this is beta software. These builds are not as stable as our official OTAs. By installing this update, you accept the potential risks. As always, please share your feedback through"
  18. FrostyFox
    Froyo Jul 31, 2021
    Exactly
    D.Sai Suhail Baba and rhyd1am like this.
  19. GauravaRai
  20. rhyd1am
    KitKat Jul 31, 2021
    As @Master_TC said, you should provide requests and suggestions to Oneplus via feedback options. Making posts here to request anything is pointless as Oneplus will never see it.
    Personally I think the included disclaimer is perfectly adequate, but I understand that you might disagree Therefore submit your suggestion through feedback
    Auristic and D.Sai Suhail Baba like this.
